I AM REPLACING THE BEARINGS ON MY MAYTAG WASHER MODEL #MVWB700VQ0
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Could you please describe the problem you are having a little better please?
Posted on Dec 02, 2012
5 Suggested Answers
Cyril J
  • 45 Answers
SOURCE: timer on maytag washer
this is a good one! dependable care unit made in my home town.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
insert flat blade under center plastic clip in the center if timer knob , you will find a little clip and sping here , then remove two 5/16 screws , then remove two phillips screws on control panel , you should see 4 ,2 on each side remove the inside 2 then tilt panel forward unplug timer. so easy
Posted on May 16, 2008
Benimur
  • 6966 Answers
SOURCE: how to remove drum bearings
This is a step by step procedure for most Maytag front loading models.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 13, 2008
heatman101
  • 43501 Answers
SOURCE: My Neptune front loading washer makes lots of
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
This tip will help with the mold problem...
http://www.fixya.com/support/r4356970-clean_washer
heatman101
Posted on May 03, 2010
caroldon
  • 17130 Answers
SOURCE: The bearings in the Maytag
If you think that there is no shake or play in the bearings a good wash with kerosene or diesel will take away all the dirt that causes the noise. The use light grease/heavy oil (90) to fill into the bearings.
Tip: repeat the washing with the diesel, use a good small brush and hold a tray under to pour the diesel and collect on to the tray till the noise subsides.
However if the bearings are still noisy then I think you need not replace the drum .
If Helpful credit me for the tip.
Posted on Aug 20, 2010
Loud washer! The last 5-7 minutes of the wash, the washer becomes very, very loud. This occurs in light loads as well as large loads. This just started about 6 weeks ago, any ideas?
My husband and I spent 4 hours Labor Day replacing the bearing and seal in my Maytag Neptune washer. Worn bearing are what is causing the loud noise. Maytag will only sell you the complete drum assembly. However, if you are mechanically inclined, you can purchase the bearings, 6206RS and 6207RS (we got ours from a local bearing company) and the seal kit can be purchased from repairclinic.com. There is a video on YouTube showing how to replace the bearings and seal. Our washer is now as quiet as it was when new!
Sep 04, 2012 | Maytag Neptune Washer
I have a maytag neptune, model # mah3000aww. Its making a loud howling sound during spin cycle.
It sounds like the drum bearings may need replacing. This is not a small job, so be sure of what you're doing before you attempt to fix it yourself. Please feel free to get back to me for instructions on replacing the seal and bearings.
Jul 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a 2 y/o Maytag Bravos MVWB700VQ0 top-loading washer that is suddenly making noise like there's either a) a chain loose in the drum of the machine, or b) a coin or other metal object is bouncing...
it is probably money in the pump. I have had my washer for two years now and an on the second pump. I had to call a serviceman to take the pump loose and dump out the change. It had 81 cents the first time and 26 cents the second. I need to call him again but I think I am going to try to do it myself. $85 a service call is just ridiculous when I know what the problem is.
Oct 12, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Makes loud noise in spin cycle
The problem is that the seals are leaking and allowing water to attack the tub bearings.
You need new tub seals and bearings.....not as difficult as it may seem.
see u tube video on replacing maytag seals and bearings
Cheers Stan
Aug 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
My maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Apr 02, 2010 | Washing Machines
Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Strange sound Maytag top load washer about 4 yrs old
It sounds like your bearings went bad. Using powder soap kills the bearings. THis also depends on the model of maytag. IF you lean the washer back look to see how many belts it has. if it has one it is really a maytag made by amana. Those are known for bad bearings. So good luck with your bearing problem. You will probably have to call out a technician Its a big job.
Nov 18, 2008 | Maytag Washing Machines
Maytag washer tub seal bearing kit - grease?
how do i change bearings and shaft ona maytag washer model# mvwb300wq0
Jun 17, 2008 | Washing Machines
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
