Question about Sony Hcd S300 Component Dvd Players
I have a Sony HCD-S300 CD/DVD Receiver but my remote is damaged. How do I change channels without the remote?
4 Suggested Answers
SOURCE: Need remote code for DVD player
Sony DVD/VCR combination decks have a Command Mode setting that allows the user to change the IR frequency that the unit accepts. This feature allows up to three units to be in the same room and be controlled separately by remote control. If the remote control and player are set to different Command Modes, the DVD/VCR combination unit will not respond to the remote control. For example, operation will not work if the remote control is designed to operate using the Command Mode 1 frequency and the DVD/VCR combination is set to Command Mode 3 .
If the remote control does not operate the DVD/VCR combination after programming for each code listed in the remote control user manual, change the Command Mode in the menu of the DVD/VCR combination unit and try programming again.
IMPORTANT: Using a remote control other than the one provided with the DVD/VCR combination deck may not provide full functionality.
Posted on Nov 17, 2009
freetek
  • 5568 Answers
SOURCE: I need the code to program sony ble-ray dvd
If the remote is more than ~ 2 years old, it probably won't have a code set for your Sony. Check the DTV site for latest code info.
Posted on Feb 18, 2010
SOURCE: sign of no disc in display
Maybe on the lens of the player.. clean the lens by using cd cleanser
Posted on Oct 23, 2012
How to repair SONY HCD-ZUX10D DVD DECK RECEIVER always display EJECT and then STANDBY ?
https://community.sony.co.uk/t5/home-cinema-projectors-players/how-to-repair-sony-hcd-zux10d-dvd-deck-receiver-always-display/td-p/2295791
Aug 21, 2017 | Sony Audio Players & Recorders
Sign of no disc in display
Oct 23, 2012 | Sony Televison & Video
I got an Sony HCD S 300 Home Theater set recently. As I put in dvds and cds for playing, the dvd player says NO DISK. Thinking it is because it is not a original dvd it isn't working, I put another DVD...
It could be down to the Region of the Player or the Laser is Failing. As it doesn't play CDs then I suspect the the Laser is Failing (almost failed if it plays a cleaner but not CDs).
May 05, 2011 | Sony DAV-S300 System
I have Sony HCD-RG290. It is telling mechanical error when i want to change cd or listen cd or open the cd-box. It gave once that error and i went to repair with it and the man said that it is really small...
I have a SONY compact disk deck receiver
model no / HCD-RG290.
Whenever i switch it on it comes on then automacticaly switches itself back to standby mode & dont know why, can you help?
my e-mail is Mark.mcevoy@hotmail.co.uk
Jan 24, 2011 | Sony Electronics - Others
I have a Sony receiver/tape deck/cd system, and need a copy of the owners/users manual in order to use the presets and other features to best advantage. The model of the unit is HCD250 or Hcd-G2000. I was...
http://www.givemefile.net/smanuals/hi-fi_hi-end--others/sony/hcd-g2000_26718.html
Above is a service and repair manual for the Hcd-G2000.
Below is your user guide.
www.devicemanuals.com/guide/.../Sony/Sony-Bookshelf-Hi-Fi-System-HCD-F250AV-User-Guide-TXpZek9EST.html
Support links for Sony below.
esupport.sony.com/
HCD250 service repair manual below.
http://www.givemefile.net/smanuals/stereos/sony/file/8297.html
Aug 24, 2010 | Audio Players & Recorders
Is there a code for multi regions for sony hcd s300
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [RETURN] Default Default region code on the player
[1] [RETURN] Region 1
[2] [RETURN] Region 2
[3] [RETURN] Region 3
[4] [RETURN] Region 4
[5] [RETURN] Region 5
[6] [RETURN] Region 6
[P. MODE] [RETURN] Only play DVDs with the selected region; auto switching OFF
[AUDIO] [RETURN] Default Auto switching ON
[ANGLE] [RETURN] Enable video interference impulses (Macrovision ON)
[SUBTITLE] [RETURN] Default Disable video interference impulses (Macrovision OFF)
[PREV] [RETURN] Enable user operation prohibitions* and access restrictions
[NEXT] [RETURN] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
Jan 12, 2010 | Sony DAV-S300 System
Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Sony Hcd S300 Component Dvd Players Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
