Question about Orbit Hardware & Accessories
I want to hard wire an orbit 57894. I cut the cord and there is no ground wire, just one black and one white. what do i do?
  • Kayee Jun 29, 2013
    I have a orbit spinkler model 57894. I have everything set up and was running fine. I turn off during a heavy rain. I turn it back to auto and accidentally hit the manuel. Now it is blinking to all my setting, the is spinkler is not on, when on auto
    President:
  • 1,714 Answers
You don't need to ground the timer case if it is plastic. That's why there is no ground.It does not need it. Only metal needs to be grounded.
Posted on Dec 01, 2012
    I have a obit sprinkler model 57894. I have everything set up .
4 Suggested Answers
  • 760 Answers
SOURCE: hello, I have 2 black wires
The timer should have red, black,blue and green wires. (no white?) If you have only the two black wires coming from junction box, then connect green to ground like you did. Connect the incoming black (HOT) to the black wire on the timer.connect the outgoing (to the light) to the blue wire on the timer. Cap of with wire nut the red wire. This is for a single pole switch installation (Only switch for the light) If this is for a 3-way control (where you have 2 or more switches) then you use the red.
Posted on Aug 05, 2010
SOURCE: I the manual wiring doesn't match what I have in
I test these timers.
GE 15071 timer has internal clock that runs on electricity. That's why timer has extra wire.
Intermatic, GE, Tork, Leviton, Sylvania, Woods, Utilitec etc in-wall timers each wire the same way.
The only tiny difference is GE doesn't have green ground wire.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Here's what to do:
1) Old switch has two screws (excluding green ground screw)
One screw on old switch has 2 black wires >> these are hot wires > timer black wire connects to these hot wires. This will power the timer.
2) The other switch wire connects to timer red wire. This will send timer signal to lights.
3) Timer white wire is for the timer clock.
Timer white wire connects to other white wires that are twisted together and covered with wire nut >>> these are neutral wires, and now timer clock will operate
4) For EZ connection to other white wires, strip back another inch on timer white wire so stranded wire can wrap like a candy cane around solid copper wires. Then twist wire nut on very tight.
5) When wiring is complete, push door on timer for manual override. Lights should turn ON-OFF. If lights do not turn on, reverse timer red and timer black wires. Make sure outdoor bulbs are working.
Add a comment any time
Posted on Dec 14, 2010
al_kupchella
  • 843 Answers
SOURCE: This is what I was
Hi Steve, I'd like to help you, but you'll need to provide a bit more information. What kind of timer is it? Is this a timer mounted in the wall like a light switch? Are you in the US (for interpreting wire color conventions)? Of the colors of wires you describe, which ones are on the timer, and which ones are in the wall box (or whatever). Good luck, Al K
Posted on Feb 03, 2011
Can I replace a white, black, and green wire pattern with a black and white wire pattern
yes u can as long as you know which color represents the hot the ground and the common
Mar 06, 2016 | Dryers
How can the orbit mdoel 57894 be progrmed for multiple start times?
The product manual is confusing... how do you set 1-5 am and 2-12 pm and 3-5 pm? The manual says to press program button to choose A B or C programs, but does not give steps for programming or when to press enter to confirm setting... or say which position the dial should be in when programming.
57894 lets you program separately for each station...turn dial to Run Time and use arrow keys to select a station. Press enter or arrow keys to advance to next station.
57894 offers 'select a station', 'pick days of the week or interval between watering for that station', 'duration of watering for that station'. But picking days of the week is not the same as setting exact times 1-5 am and 2-12 pm.
The dial is set to auto for programs to operate..
Don't forget to activate battery located top right on face of timer.
http://waterheatertimer.org/pdf/Orbit-57894.pdf
So the 57894 has more options than a 24-hour analog sprinkler timer that repeats same cycle each day with 14-day-skipper.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
Mar 12, 2015 | Orbit Hardware & Accessories
Emergency power cut now won't start
you cut cord have open circuit.your electrical cord has three wires neutral wire white wire black wires hot wire and bare wire for ground. if you cut either neutral wire or hot black wire in the electrical cord no power can flow to trimmer motor if you cut wire need to fix wire to get trimmer work again.
Dec 24, 2012 | Cars & Trucks
Cut the cord. what is the color code of the wires? I have a green, black and a white wire.
Hello, black is the line or "hot" wire. White is the neutral and green is the ground wire.. On the cord end the black goes to the smaller of the two parallel blades and the white to the larger. The green goes to the one that is more round, the ground.
Feb 20, 2011 | Philips Power Strip 6-ot 8
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
I'm replecing the power cord on my Kenmore
The earth wire ( ground) is only used to earth metals on/in the appliance.
If the appliance is double insulated ( I suspect it is ) you can safely cut off the ground wire.
You can identify the system used by 2 squares symbol, one inside the other which means its double insulated
Nov 27, 2009 | Sewing Machines
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
Where can I BUY THE cords at.
I've never seen the ad for a weed thrasher but, as far as a replacement cord goes. You can buy a extension cord of the same size and install it. Just cut off the end. The wires within the cord need to be the same size or bigger, never smaller. Also it's important to replace a 3 wire cord with a 3 wire cord. You can use a 3 wire cord with a machine that came with a 2 wire cord, just cut off the green wire at the machine end. Your wire colors should be white, black, and green. Black and white are your power wires and green is your ground. Usually black and white are interchangeable but, on occasion switching them may make the unit run backwards so install them in their original position. Write down where they where hooked up and install your new cord in the same places.
Mar 23, 2009 | Weed Thrasher Replacement Cutters As Seen...
Hardware & Accessories Logo
477 people viewed this question
Top Orbit Hardware & Accessories Experts
appman67
appman67
 Kenneth
Kenneth
Andrew Taylor
Andrew Taylor
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
