Kenmore pump replacing pump, can't remember which color wire goes in which part.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 02, 2012
Rodeo fuel pump rewire
Usually on these it is the fuel pump sending unit. But here is how the wires connect. Here is what you need to do about the different wire colors. First disconnect your negative battery. Drop the fuel tank and replace pump. Remember to have a splice kit in hand. Ok now here is how you connect the different colored wires. Black goes with black. Gray goes with black and orange wire. Purple goes wit blue and yellow. And the last wires goes together. I hope this helps.
Sep 30, 2014 | Cars & Trucks
Motherboard connections (to front panel)
remember the colored wire is +, the + and - should be printed very small on the board near the connectors as well as what they are example (HDLED is hard drive LED) or (PWRLED is power LED) or (PWRSW is power switch) these are examples yours may differ slightly
Jan 31, 2013 | Gateway (4000811) Motherboard
Need color code on new connector
Just did my fuel pump on the 2001 isuzu rodeo. Well here is what you need to do about the different wire colors. First disconnect your negative battery. Drop the fuel tank and replace pump. Remember to have a splice kit in hand. Ok now here is how you connect the different colored wires. Black goes with black. Gray goes with black and orange wire. Purple goes wit blue and yellow. And the last wires goes together. I hope this helps.
Aug 12, 2012 | 2001 Isuzu Rodeo
What does the code F33 mean
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit). Remember to disconnect power to the washer before attempting access. could be a bad pump or loose wire connections. good-day !
Nov 17, 2011 | Kenmore Washing Machines
I just replaced the heating element and cant remember how the wires go
Hi Coach,
I found this in a fixya thread for your machine, so don't credit me with this, but it appears this is the solution.
the 2 wires that go to the element are largest. Does not matter which one goes where. The other 2 wires are smaller and impossible to get on the wrong terminal.
Thanks to Tbirdfan1 for this solution.
Sep 14, 2011 | Kenmore 62622 Electric Dryer
I replace the fuel pump on my 1992 ford bronco and still doesnt supply fuel is there a relay i dont know of
Are you getting battery power and ground at the fuel pump connector? (This should have been checked BEFORE replacing the pump)
Other things to check:
1. Fuel Pump relay in the Engine Compartment Fuse Block
2. The relay is powered (Secondary -or- "fuel pump side") by Fuse 0 in the Engine Compartment Fuse Block.
3. The relay Primary -or- "control" side is powered by Pin 37 RED wire at the PCM
4. The relay Primary control (or ground circuit) is operated by Pin 22 LIGHT BLUE/ORANGE wire at the PCM
5. The Inertia Fuel Shut-off Switch located between the fuel pump relay and the fuel pump may need to be reset. The switch is located behind the right kick panel. The DARK GREEN/YELLOW wire at the switch is the feed from the fuel pump relay. The other wire goes to the fuel pump. Some units have the DARK GREEN/YELLOW wire going in and the wire going out can also be DARK GREEN/YELLOW, or PINK, or ORANGE - the wiring diagram for your vehicle does not specify the color of the wire that actually goes to the fuel pump itself.)
6. If none of the above produce any results, make sure that your ground wire at the fuel pump has good continuity to ground. It usually screws to the left frame rail near the fuel tank.
Any of these components (including the PCM) or their connecting wires could be the cause of your problem.
May 15, 2011 | 1992 Ford Bronco
I have a Kenmore HE 2 Plus washing machine model 8540912 with F21, F33 & 5D error codes. Can I twist and remove the water pump filter on this unit to check for clogs? Thanks.
Please see the following image provided for instructions.
CLICK HERE
Thanks for using FixYa^&%$
Oct 07, 2010 | Kenmore HE2 Plus Front Load Washer
Power cord was ran over by lawn mower and cut into a black and white wire from inside was unplugged at this time I need to know where does white and black wire plug back in
Is this 110 volt or 220 volt?
110 = white wire goes to the neutral side of the circuit ... or the silver color screw on the plug. The black wire goes to the brass color screw ... or the "hot" side of the plug. The green wire goes to the green screw.
220 = youwill find on the 220 20 amp plug there are two brass colored screws + a green screw for the ground.
Aug 22, 2010 | Intex '10 Saltwater System Pool...
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
