Question about Pool & Spa
Teledynelaars laars ec325 won't ignite
I get spark but no flame or gas ignition
SOURCE: Igniter
Make sure porcelain tipped ignitor is clean and dry after cleaning stove top.
Posted on Jan 05, 2008
dauphine
  • 207 Answers
SOURCE: No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Posted on Apr 09, 2008
SOURCE: Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Posted on Oct 27, 2008
SOURCE: GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Posted on Dec 30, 2008
  • 9 Answers
SOURCE: Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
Posted on Jun 28, 2009
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
Teledyne ec-400 pilot light won't light up? I can see it sparking but no ignition? Just replace the pilot burner assembly.
make sure 24 ac volts to gas valve between brown wire and ground if not check safety circuit
May 05, 2012 | Teledyne Laars Pool & Spa
IT TURNS ON THEN SHUTS OFF,DISPLAY FLASHES SERVICE AGS
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
John
May 29, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Electronic spark not working
Lite with a flame the ignition buttons NEVER work even when NEW
http://www.laarsman.co.uk
Miles
May 19, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot Flame will not ignite
Clean the pilot tube of rust or other debris.
Jul 10, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
May 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lite 2 Spark egnighter will not spark
turn power off first. I would disconnect igniter wire which will be a thick orange wire that comes off of ignition module if it is spark. once you have that the end will look like a spark plug wire take shield away from metal then hold orange wire in hand close but not touching metal turn power on and it will take a couple of minutes before it should start sparking. If you don't see a spark then it is most likely the ignition module. There should be a red light on ignition module that will blink to tell you what the failure is if is is a newer on. When you turn power on to laars light 2 the inducer motor should come on then a pressure switch should send 24volt to gas valve for pilot to lite.Can you smell gas at all when laars should be igniting. If you have any questions fell free to email me back
May 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pool & Spa Logo
54 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
