Question about Maytag MER5775Q Electric Kitchen Range
Heating element burned out replaced it now it wont heat up
The Element got really bright then it had a little flamed on it, it went out took it out later put a new one in and it still won't heat up.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
You can test your oven sensor 12001656 to see if it is bad. At room temperature they should ohm out at 1100. If it does not then it will need to be replaced. Here is the sensor to order.
Posted on Dec 02, 2012
SOURCE: need to replace heating element
We have a maytag stove and we cleaned our oven on the self clean cycle a week ago. I used the oven once since we cleaned it. today we went to use the oven again, and the oven will not heat and the broiler will not come on either....seems funny that both would quit working at the same time.....any suggestions....
Posted on Jan 16, 2008
  • 1314 Answers
SOURCE: Looking for the part no.
the part you need is called the upper oven hi limit thermostat any appliance parts store can get it with your model number and any stove wire will do if you cant find it there then try here http://www.pcappliancerepair.com/cgi-bin/promotehome.cgi?affiliate_id=GSMK01ag
Posted on Feb 11, 2008
SOURCE: Gemini MER6769BAW Range/Dual Ovens
depending on type of unit. most of the time they are very easy to change out.. look at element locate two screws. go shut off breaker to oven.. make sure its has no power. after removing screws element should come out fairly easy.. make sure not to let wires fall back inside unit. if so not to worry. just pull unit out from wall and remove back panel. push wire back through. hope this helps
Posted on May 15, 2008
garing
  • 998 Answers
SOURCE: lower element of top oven does not heat on Maytag Gemini
replace the control
Posted on Aug 06, 2009
SOURCE: Baking Element Caught fire
funny same thing just happened to me and it all seams to be the bottom element of the same ovens around the same year, I bought mine in 99 also, I keep my oven very clean becasue i know the dangers it may cause, I think this is a major problem and it needs to be addressed.
Posted on Dec 11, 2009
Model 790.96009601 I replaced the heating element that burned out. New heating element does not work.
The replacement heating element could be defective, not burned out. Also, the replacement element could have been installed incorrectly.
Oct 29, 2014 | Kitchen Ranges
My GE Profile JVM1790 convection microwave has issue. Was using the convection portion when a small spark and flame appeared and then went out and soot and smoke was all inside and now will not heat up...
Yep, that sounds very much like the heating element burned out. It happens. You should be able to get a replacement from the manufacturer's website... or there may be a list of repair centers in the manual - pick one & try to order the heating element through them.
Aug 13, 2014 | GE JVM1790 Convection / Microwave Oven
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Dryer not heating
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
Whirlpool electric dryer high thermostat replacement
test all this steps in according with your model, electric or gas. God bless you
Thermal Fuse
Gas Valve Solenoid
Dryer Igniter
Heating Element
Flame Sensor
Cycling Thermostat
Main Control Board
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer.
Jul 21, 2013 | Dryers
I have a Kenmore 80 series gas dryer that will not heat up anymore. I took off the small clip in front and can see the heating element start but no flame or heat . Also the dryer will make an intermittent...
check the thermal fuse on the blower housing,if it shows good then possibly the gas valves are weak on the burner tube and wont let gas into the burner
Nov 18, 2010 | Kenmore Dryers
Heating element burned out (literally!)
No you are fine...just replace the element, they will fry like that sometimes...
Check out this tip that I wrote about this problem...
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 29, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Flame from electrice heating unit with range turned off
Your bake element blew out. Easy to replace... turn off the power (unplug) and replace the element by removing two screws holding it into the oven. Then you have two wires to the element and they either push on or have screw on terminals
Dec 22, 2008 | GE Spectra JBP78 Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
54 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
