Question about True GDM-41 Refrigerator
How do you evac and recharge a true freezer compressor??
Line broke,repaired line need to recharge system
  • Todd Born
    Todd Born May 11, 2010
    the above is true. except that its the kyoto protocal. You do need to find someone that has a licensed tech to properly evac and recharge the unit for you.
  • Mathew F
    Mathew F May 11, 2010
    Sorry mate but to do that you are going to need refrigerant (freon) and only people that have a refrigeration license can buy refrigerant according to the kioto protocol.
    I think you are going to have to call a licensed refrigeration tech
    If you had a licence I would be able to talk you through it but you are still going to need the freon
  • 306 Answers
Your unit takes R-134A you can buy that anywhere it is 0 depletion on Ozone. The hard part is getting access to your lines if you have a service tap installed piece of cake. They make a saddle valve you can install to access line set. Pull a vacuum on unit takes a vacuum pump and about one hour of running the vacuum. Just put one line tap on the line and be sure it goes on the low pressure line not the high pressure side. The unit the fridge only takes about 5 ounces of refrigerant and has to be weighed in. Also has to be put in as a liquid as this is a blend of refrigerants. As long as you have gauges and pump and a scale I can walk you through it step by step get back with me and we can do that. ken
Posted on Jan 11, 2009
  • 700 Answers
Here's a good informative link for you to read http://www.rses.org/main/sam/xml/630-122/630-122.xml this is from the refrigeration service engineers society very informative
Posted on Jan 15, 2009
Compressor keeps turning off and on. Stays on for about a minute. Cycles off. Then stays off. Does recycle after a few minutes. How do I add coolant and where.
It is normal for the compressor to cycle - when a certain pressure is reached in the system, a pressure switch disengages the compressor clutch, and then activates it again when then the pressure drops below a certain point. Unless your air temperature doesn't stay relatively constant, there is no need to do anything. If it doesn't, the system may need recharging and that should only be done at a certified repair shop.
Jul 06, 2017 | AC Cars & Trucks
02 Lancer air conditioner
The compressor must be the problem based on the price of the repair.
Oct 18, 2012 | 2002 Mitsubishi Lancer
Need to know if any oil is needed on ac compressor
only if you have installed a new compressor if its just an evac and recharge then the PAG oil is still in the system...............
Sep 01, 2011 | 2002 Suzuki XL-7
When doing an Evac of the AC system where do you hook up the vacuum pump to the high side or low side fitting. The vehicle has to not be running also, right? I just replaced the AC compressor, the...
any charge port will evac the system
the compressor will not be running
adding oil is not necessary as there is enough in the replacement compressor
run the vacuum pump for a couple of hours and then lock of the system to see it it holds vacuum
May 07, 2017 | 1996 Toyota Tacoma
How do you change ac compressor on a 2000 nissan sentra
hook the high and low sides of the ac to a evac/recharge machine at a repair shop and evacuate the freon. apply a vacuum to the lines. measure how much oil comes out. disconnect the two aluminum lines from the ac pump, remove the serpentine belt, remove the (probably) 4 small long bolts. remove and install new part. reattach lines. do NOT overtighten lines. recharge ac refrigerant to specified ammount. if the pump is new you will have to measure how much oil comes out of it and put in that much oil in the new pump or it will burn up. if you dont have a evac/recharge machine they cost around 3000 dollars.
Mar 23, 2010 | 2000 Nissan Sentra
Freezer compressor runs loud and rough
Not if the repair was done correctly. The oil was probablly lost with the refrigerant and it sounds like it (the oil) wasn't replaced.
Mar 10, 2010 | True T-49 Side by Side Refrigerator...
Freezer compressor loud and rough
No it isnt, it sounds like he overcharged it. Call him back and tell him to try again.
Air leak
You can replace the section of line but you should really have the dealer or a third party A/C shop do it for you as they can evap the lines (there must be a vacum) and then add the R134a with some oil etc. Expect it to cost ~250$ or more.
Jul 02, 2009 | 1999 Mercury Sable
True GDM-41 Refrigerator Logo
947 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
