Question about Konica Minolta DiMAGE Z5 Digital Camera
Change the batteries cover
I need to change the cover of space batteries. I saw that there are two small screw, I need to open from that? Tnx Gino
I'm not an expert by any means, but that does seem like the way to take it apart and fix it. I have the same camera and the same problem. Where did you find a replacement cover for your batteries? Thanks & Good Luck! Free Eagle
Posted on Sep 26, 2007
SOURCE:
How do I change the battery on my zebco 33 live bait reel
take it to your local tackle shop, it needs taking apart and resealing
Apr 09, 2014 | Sport & Outdoor - Others
How to change irulu ax922 tablet battery replacement
The most Irulu tablets have 2 small cover screws on each side, pop the cover unscrew it and open with careful. the battery is connected inside its a square white plastic cover connected to the motherboard . Hope this help.
Mar 20, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Np 550pc7-s02uk
you will first need to unplug your laptop from the power source then remove the battery, when the laptop is turned upside down, there should be a cover on the back of the laptop, use a small screw driver to open the back cover, and then you will be able to pop out the ram and put the new ram in, it will click in place, good luck
Jul 28, 2013 | Samsung Computers & Internet
Changing the battery in a mickey mouse pocket watch
The first answer is a canned answer. Seen it before. Examine the edge of the pocket watch. Start at the stem and look for a slight gap where the back cover meets the case. It is usually at the stem side or hinge side. Once located take a strong sharp knife and carefully pry up the back cover. It should remove fairly easily. I have about 12 pocket watches and they all work the same way. Once open there may be a small screw or two holding the battery in place. You will need a precision screw driver set or a small screw driver for glasses.
682b943c-dbb9-4041-9abb-ed1a67105d52.jpg eff96e41-9266-48e7-9603-ac9206c667a0.jpg 03735b42-603a-41af-9aa7-4d445bd017dc.jpg
Jun 30, 2013 | Watches
Franklin crossword puzzle solver CWM-108 how do you change the battery instructions say remove screws from back, no screws just moulded holes,
There is a square section on the bottom with a slide switch next to it. Slide the switch away from the hinge and open the cover section. You may need to give the case a squeeze or slot a small screw driver into the edge of the cover section.
Sep 19, 2011 | Computers & Internet
Please tell me your closest technitian in Norcross; Georgia 30093 My Chain Saw is not turning on
i cant tell you were to look but i can tell you what to look at on the saw to try to fix it,,,,first change the spark plug and check for a spark by holding the plug on the cylinder head and cranking the motor over,,,hold it down tight or it will bite you?
then check you have a clean carb and that the fule pump rubber is good,,its under the cover were the fule pipe fit on the carb clean the carb out as well,,clean the air filter out,, then give it a go starting her up,,if she runs but keeps stoping get a small screw driver and find the two small screws on the side of the cover,, one is for slow running,,one it for top reves,,,undo the slow running screw till the saw ticks over without stoping,,then hold the triger full open and addjust the full throtol screw till it wont rev any higher,,,dont have the chain brake on at all so watch your self,,,,,cutting a leg off hurts im told????
Aug 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How do I change the battery on a chamberlain keypad for a garage opener
There is a small phillips head screw near the bottom on the front of the keypad. Remove this and then the small cover.
May 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
1998 mercedes benz e320 key does not turn or unlock doors
All keyless-entry keys have small batteries which runout in long term, some has small screws which you can open and change the battery and some needs to be replaced with new keys, have a look at your car's key and see if you can open the plastic cover and change the battery. Hope it helps and please don't forget to rate the answer if it was helpful, thanks!
Mar 09, 2010 | Mercedes-Benz E320 Cars & Trucks
How to change back up battery on TI-83 Plus
Remove the battery compartment door. Use a small Philpps screew driver to loosen the screw hodlding the plastic cover of the backup battery. Insert the tip of the screew driver or a pen, in the space to the left of the battery to lift gently the battery. Be careful, there is a spring under the battery.
Inser the battery with the positive pole (+) on top. Reinsert the black plastic cover on top of the battery. make sure that the small tip of the cover is inserted in its location. Tighten the screw and replace the battery door.
Hope it helps.
Nov 08, 2009 | Texas Instruments TI-83 Plus Calculator
Konica Minolta DiMAGE Z5 Digital Camera Logo
75 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
