Question about Mitsubishi WD-62531 Projection Television
I have a mitsubishi WD62351, plays for an hr our so then turns off,
I have to unplug the TV and then plug it back in again to get it to work. Is this a lamp issue? What needs to be done?
SOURCE: WL-82913 Lamp fails and TV turns off every hour or so
We have the same problem. A 14,000 dollar TV that you cant even get a lamp for. I 'm thinking of a class action lawsuit. This is ********!!!!!!!!!!!!!!!!!!!! Please respond if your interested
Posted on Jul 29, 2010
designer7
SOURCE: Blinking Green Light
Hmm I tried unplugging it for a while but I will try this again tonight since it will be unplugged for about 24 hours.
Thank you McColp for the info..
I have a service guy coming tomorrow, maybe this will work before he comes! I appreciate your help!
take care
Maria
Posted on Nov 02, 2007
  • 1030 Answers
SOURCE: TV suddenly shuts off and lamp light comes on, but lamp is OK
did you reset the lamp timer? just a guess
Posted on Feb 08, 2008
  • 395 Answers
SOURCE: DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Posted on Feb 21, 2008
SD Tech
  • 14553 Answers
SOURCE: unplugged tv before storm, tv was running fine
2 possible problems--this set has a receiver box in the back(left side as you look from back) if it is gone the green led will never stop blinking---if you unplug the set and plug it back about 70 seconds later the led should stop blinking--this is boot up for that box----the only thing other than that will cause this trouble is if the reset button on the front of the set is bad--if you remove front speaker grill and unplug the one or two plugs that go from the front keyboard the set should still turn on with the original remote---then you can leave them disconnected and just use the remote---if the set still does not turn on---the receiver is bad--only way to get this part is remove the original receiver and send it out for rebuild--very expensive and usually not worth doing--the part is no longer available from Mitsubishi---and when it was it was about 800 dollars---a rebuild of your current unit will be about 300 dollars plus labor to remove and re-install -----if you have any questions or need more help---
etower.766@netzero.net
If this is helpful I would appreciate a vote here from you.
Regards, Steve
Posted on Aug 11, 2009
Mitsubishi wd-65734 65 in. Tv shuts off on its own and red lamp light comes on. after a few minutes i can turn it back on and works fine for a few min to an hr before doing it again. anyone no wat the...
Same thing on my tv after replacing lamp. Lamp manufacturer advised me that after changing bulb, tv must be reset or tv will go into safety mode and will not turn on. To do this on my model WD-65734 you must hold reset button in with a pen or paperclip for about 10 secs.The LED will start blinking for a few mins. When itstops you need to unplug tv set for about 1 hour. After this the tv will be reset.
Apr 22, 2012 | Mitsubishi WD-65734 65" HDTV
Mitsubishi vs 60707
pleaser eset you TV as below.
Turn off and remove the power cord from the main socket.
leave it for about 30 min
turn back on again.
please make sure your sleep mode is off.
May 19, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
Feb 24, 2011 | Mitsubishi LT-40153 LCD TV
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Unlock code
while the tv is on, unplug it for 20 seconds, then plug it back in, should turn itself back on, but if it dont, turn it back in yourself, most of the time it will fix the issue
Jan 11, 2009 | Televison & Video
WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Dec 13, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi model WT-A42
maybe theres aproblem between the power supply and in the horizontal circuit of your tv
Jul 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv wont turn on
First reset the TV set by unplugging the AC cord for like 5 minutes. then plug it back on again, try turning on the TV, if it still dont turn on then I suspect a blown fuse or worse.
Jun 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WD-62531 Projection Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
