Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sony Bravia - sound pulsates off and on - several minutes on and then 10 seconds off. We checked cable box and HDMI cord on another TV, and sound was fine, so narrowed down to the Sony Bravia.
  • Sony Master
  • 736 Answers
Actually try one more thing before concluding that there is something wrong with the sound board or one of the wires in it on this Sony Bravia television. The cable box settings might not be just right for this television. Are you currently set to pcm or bitstream on this cable box? pcm might also be displayed as 2 ch 48 or 96 khz. Play around with the sound settings and see if one or the other will solve this sound issue before writing off the television.
Posted on Dec 01, 2012
HDTV GURU
  • 261 Answers
SOURCE: Sony Bravia KDL52XBR5 picture blanks out using HDMI port
I think this has to do with the cable box not liking the encryption thing going on with the sony tv. The cable boxes probably don't understand it fully and therefore you have intermittant problems. I would just use component inputs. Which are analog and no encryption problems. I hope this was helpful. I bet it doesn't happen using a sony DVD Player or a blue ray DVD Player either. Sony, Sony, Sony.....Good stuff...but they have their moments. Let me know if u come up with a fix for this and then i will post it on my fix it list.. Thank you again..GURU JAY
Posted on Feb 08, 2008
mjjdesigns
  • 98 Answers
SOURCE: sony bravia klv-32t400a hdmi input through x-box
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Posted on Mar 19, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Posted on Apr 01, 2010
  • 608 Answers
SOURCE: Sony Bravia model #KDL52WL130 worked
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years, some sooner, because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
I have a sony bravia 40 inch hd tv. i also have a comcast hd box that always worked on the tv through the hdmi. One day i was having trouble with cable box so i unpluged it to reset it. now my tv will...
Your PS3 working doesn't mean a thing for the cable unless you are using that cable for your PS3. I would bet you have a bad HDMI. They are pretty sensitive to being bent. Try replacing that first. The other thing to check is to first make sure you have the proper input selected on the TV for where you have the HDMI plugged into on your TV.
Aug 25, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The word debug is on the screen. how do i take it off?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.
Feb 27, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
I hooked up my tv,a sony bravia bx3 to my laptop using an hdmi cable which i disconnected from myps3 while it was still on,it worked perfect.suddenly the ps3 switched off.I re-connected my ps3 to the tv...
ok you have to reset the ps3 by turning of backswitch wait 10 seconds turn on the backswitch then press and hold down the front power button for 10 seconds you should hear 2-3 beeps that does it just wait and the video settings have automatically detected your tv settings and are going to ask you to save hit x to save display settings on ps3 remote problem solved. If you still get problem message me cause its technically bad.
Dec 15, 2010 | Video Game Consoles & Games
Sony Bravia KDL 52Z5100 - no sound only picture. HDMi cable works fine with another TV, so no probs with cable TV.
A short fix is to unplug the hdmi cable and shut down the tv compleetly, then get the tv on and plug it in, the tv see the new connection and reset the value's for sound
Feb 15, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have an HDMI cord hooked to my Bravia it is set on video 6 the cable box is powered on and funtiona and the HDMI cord is good. I am getting no sound and no picture is there any way to test the HDMI port...
if you have video im assuming you do if you can see its on video 6 look at hdmi port and make shure its video 6 if your not shure leave it hooked up the way you have it turn on cable box and go thru all inputs example put it on video 1 wait for 60 seconds if nothing happens go to video 2 and so on and so on be shure to wait at least 60 seconds before you change to another input good luck
Feb 03, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a brand new LG 50 plasma and a Bravia Sony surround sound system as well as a Cox Cable HD DVR box. I currently have it connected as such: HDMI from Bravia Sony System direct into TV HDMI from Cable...
you may have to set the input value on the bravia for optical on the input from the cable box. sometimes there is more than one way for a particular input to receive an audio signal, you may have rca(red and white), a black or orange rca type for digital, and then the optical. i would suspect you have to tell the bravia how the sound is inputed into the bravia. also , just a thought.... on the cable box there should be a volume control on the front of the box........ make sure the cable box volume is ALL the way up (it is the preamp volume).
Dec 08, 2009 | LG 50PX5D 50 in. Plasma HDTV
Trouble hooking up sony components..Bravia, Home theatre, blu-ray
Got your post, I will work with the model #s. Get back with you soon. Also a tip for now: HDMI carries true digital video and audio so you may not need the optic cables.
Lone99star
Jan 30, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Popping noise
Our Sony (almost new) is experiencing sound problems. The sound go off and on about every 10 seconds. Cords appear correctly connected. It sounds as if its coming from the television.
Can you help with this problem?
Thanks,
Mike
Oct 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
160 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
