Question about Sewing Machines
I need to find out how to thread the machine. can you show me?
Its a limited edition
  • Sewing Machines Master
  • 7,365 Answers
What is the name and model number of the machine ?
Posted on Dec 02, 2012
2 Suggested Answers
SOURCE: Top thread on my Brother
rethread the machine
try a top thread tension of 3 or 4
change the needle
always keep a thread tail of 3-5 inches on top & bobbin thread & keep the thread pulled back behind needle before starting to sew
always keep the bobbin area clean of lint & loose thread
& check under the needle plate for lint also
you might consider having the machine serviced, since you said it sounds like a tractor
some needle & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Posted on Nov 04, 2010
When sewing the thread coming of the bobbin bunches up and jams the machine it even does the same thing on my digital brothers ce1100prw project runaway limited edition computerized sewing machine
Sounds like bird nesting or thread nesting--I prefer to call it "thread mess."
Be sure to start with a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point and test your machine.
Adjust the top tension as needed so the top and bobbin threads meet in the middle of the fabric.
Happy sewing!
Jan 04, 2018 | Sewing Machines
Brother LB6800PRW Bobbin Tension?
I suggest having the top tension checked by a sewing machine technican,, and since the bobbin case screw is painted with green ,, I suggest having it checked also to make sure the tension is correct on it. also make sure the bobbin is inserted correctly--counter clock-wise..
Dec 17, 2014 | Brother LB-6800PRW Project Runway Limited...
Every time I use this machine something else is wrong with it :-(. Now the bobbin thread us bubbling up in the back of the material and there is a grinding sound as the needle hesitates to move. What
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Nov 09, 2014 | Williams Brother PC-420 PRW Limited...
Difficult to use auto needle threading
you thread the machine the normal way, using every thread guide, and if the automatic theader works it will thread the needle,
if the auto threader doesn't work, then it needs to be checked.
also make sure the needle is turned the correct way and inserted correctly into the needle holder.
Mar 06, 2014 | Brother 50-Stitch Limited Edition Project...
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Mar 06, 2017 | Brother CE8080PRW Limited Edition Project...
Bobbin is very loose when sewing
try adjusting the top thread tension to one number or letter higher
until the stitch look better
change the needle
Aug 28, 2012 | Brother CE8080PRW Limited Edition Project...
Viking Designer SE-Limited Edition 43 hours of sewing. bobbin thread comes up around edges of desing
try changing the needle
check for burrs in the needle plate area & bobbin area
check also the top thread tension
Mar 12, 2012 | Husqvarna Sewing Machines
Top thread on my Brother Limited Edition 350 Sewing machine keeps breaking. Having used the automatic cutter, the thread pulls up and out of the needle when I want to start sewing again. Also the machine...
change the needle
Nov 04, 2010 | Brother Sewing Machines
I have a New Home Limited Edition Model with
i need help to fixe my house and i need moneyto gate my work autorization
Dec 09, 2009 | New Home Sewing Machines
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
