Question about Dryers
My GE Model # GTDP350EMWS shuts off within ten minutes of use please help me figure out how to take the dryer apart so I can check whats wrong with the filter or thermostat...Thank you for your help.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Below is a video to show you how to open the unit. You will need to check the blower and motor for lint buildup. The motor is overheating. If those parts are clean, you will need to replace the motor. Here is the motor to order.
Posted on Dec 02, 2012
SOURCE: The diagnostics say there is nothing wrong with my dryer but...
I had the same problem and my dryer was 2 1/2 years old. I also thought the problem was with the blower motor. However, the blower motor checked out fine. It turned out to be the Main Circuit Board. This is covered in the 5 year manufacturers warranty. If you don't go through GE warranty, it will cost you $170-$200 plus labor. Our technician said this is the third unit he has seen that this has happened to. If you do use GE Warranty it will cost you about the same as the are proud of their labor rates. Here is the part: http://www.easyapplianceparts.com/Search_Detail.aspx?Inventory=959920&SourceCode=6 Good luck and I hope this helps!
Posted on Sep 28, 2007
MNTECH
  • 1543 Answers
SOURCE: LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
  • 228 Answers
SOURCE: Bosch condensation dryer model WTL5400vc. lint filter alarm
there is a reservoir in the base of the dryer which holds some condensing water prior to the pump pumping it to the holding tank at the top this has a float swith to tell the pump to come on and drain water to top tank this is probably stuck in the on position so the machine thinks it is always full of water and its waiting for you to empty it,you need to remove side panel and remove flost switch to clean, remove condenser and put youre hand in back of unit if its still very wet in there thats the problem should be bone dry at end of cycle.
hope this helps
Posted on Jul 22, 2009
  • 4088 Answers
SOURCE: GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Posted on Aug 28, 2009
What is wrong if my Frigidaire front load dryer
Thank you for your inquiry, friend!
I understand that your Frigidaire dryer has been providing you with an error code "PF". Typically "PF" stands for power failure this can happen if power is shut off during a cycle or the dryer receives insufficient power, which could be an issue with your power cord or control panel. Let's perform a reset on your dryer and you can do this by unplugging the power cord for ten minutes. If you need any additional assistance please feel free to reconnect. -Matt
Oct 14, 2014 | Dryers
Ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Inside the back and the bottom of your dryer are several ( From 2 to 6 ) "overheat thermostat switches".
One of these is doing it's job really well.
These are designed to prevent your dryer from overheating and catching fire.
I suspect one of them is failing, and needs replacement.
Someone handy with electrical testing tools and mechanic's tools need to take it apart and check these to find the "bad" one.
While they have it all apart, it should need a really good cleaning inside.
Be blessed.
Mar 22, 2013 | Dryers
Frigidare dryer gleq215ee won't heat then shuts off after about 10 minutes. 4 lights on right flash. no error code comes on. I am pretty handy and can take apart and fix. would need to know what t
Hello John Sterns - First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Dec 09, 2012 | Frigidaire Electric Dryer
Dryer heats and then shuts off
know that it can be very frustrating to have issues with your dryer. If you have to wait for it to cool down before it will start again, this is an indication of the motor overheating and shutting off on the motor thermal overload. This can be caused by the motor being covered in lint or a low voltage supply to the motor. Check and clean the motor of lint and see if it runs normally.
Oct 14, 2012 | GE Dryers
I have a GE Dryer model DDE9605SBMAA that is just making a noise when I push start. It isnt the belt I have checked. What could be wrong?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 20, 2011 | GE Dryers
My GE gas dryer is gets warm but the clothes take hours to dry
Hello there, this could be quite a few things.
The most likely cause is something as simple as a clogged lint trap. I will assume that you have checked this out, but just in case check it one more time and use a flashlight to see if you can spot any lint trapped down a the bottom, below where the lint trap sits.
Secondly, during the summer if you live anywhere where it's humid it will be much much harder for your dryer to do it's job. I was perplexed by this same problem when we moved out here to Minnesota. I thought my dryer was broken for sure, the clothes were warm, the dryer was warm, but the clothes took literally a full day to dry, many many cycles. Is there a chance that this is what you are experiencing?
Lastly, and the most complicated of the bunch, could be a shorted element. If that's the case you could replace it yourself if you are comfortable taking apart the dryer. If it's a newer GE dryer though it's probably still under warranty and they will take care of it for you. I would check with GE in regards to the warranty status. Their phone number is 1-800-626-2005
If none of these things work, please reply (if you can reply within the next 20 minutes or so it will assure that I am the one who continues with the question) and in your reply please include the actual model number of the dryer if you could.
Jul 08, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
My dryer sounds like ''crickets''???
Replace the rear drum bearing, part number WE3X75.
Jun 07, 2009 | Dryers
Dryer shuts off after 15 minutes and needs to cool down then will start again and the cylec continues!!On, off,on, off.
The problem is more likely a high temp limit switch. I don't have a schematic of your dryer, but one should be included somewhere on the dryer. You have to use a voltmeter to test the components in the circuit. The thermostat controls the heat temp, you may want to start there
May 07, 2009 | GE DVL223EBWW Electric Dryer
COnverting it to propane
You need to change the orifice on the end of the gas valve and flip the cap on the regulator to the LP side. Model number would help.....?
Oct 30, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
