Question about Graff Plumbing
Graff perfeque model g1700lm3 replace cartridge
My Graff kitchen faucet just started leaking slowly. What needs to be replaced.
it depends on the type . if new enough it probably has cartridge if old it probably has washers. this is one site I found http://www.chicagofaucetshoppe.com/Graff_Faucet_Parts_s/8628.htm
Jan 22, 2015 | Graff Plumbing
Midway point between Irvine KY & De Graff OH
If using I-75 halfway is a little south of Cincinnati...
Sep 20, 2014 | Cars & Trucks
Remove the handle from graff kitchen prescot faucet- stuck
you may have to use a little force gently pry under the handle be extremely careful not to break handle i usually take a piece of wood to put up against faucet or whatever and then tap faucet with hammer then start prying back side with a screwdriver or small breaker bar use your hand to try to wiggle the handle
Aug 30, 2014 | Graff Plumbing
My graff shower assembly is dripping from the tub spout when the water is off. What are the most common reasons for this? I recently had my water line to my house repaired and wonder if some dirt may have...
maby there is dirt traped behind the showers lock rubber. bt it sounds to me like it is the lock rubber(close) rubber that has parished. replasing the rubber should fix it
Jun 15, 2010 | Graff G-7065-LM15S-P ; G 7065 LM15S P...
Tem adj
Remove the handle and the chrome bonnet. You will find a white plastic or brass gear drive system. simply remove the gear and position it farther down the line until you have reached your desired temp settings
Feb 19, 2010 | Graff G-7070-LM27S Tango Series Pressure...
Where do i get repair parts for graff shower valve
They can be found easily at amazon, click here: Amazon com graff shower parts and take a look. Have a nice day.
Thom
Dec 01, 2009 | Graff G-7070-LM27S Tango Series Pressure...
Installation of the Graff pop up drain plug
if you losen the nut the bolt is adjustable make sure you tighten nut
Apr 12, 2009 | Plumbing
Plumbing Logo
106 people viewed this question
Top Graff Plumbing Experts
Donni Steen
Tom Chichester
Are you a Graff Plumbing Expert? Answer questions, earn points and help others
