Question about Toshiba Computers & Internet
I have constant trouble with my toshiba laptop using windows vista constantly losing the dial up internet connection.
Windows vista. loses dial up internet connection very frequently. The modem has been checked by the service provider..time warner cable & the signal to the modem is fine.
    Scholar:
  • 156 Answers
If your telephone line may have disturbances from any electronic devices at any point then this could happen. Try moving other devices especially speakers, mobile phones and TV near the modem. Does your laptop wifi enabled one? Do you use telephone in that line? If so use a line filter with two out. could you give your laptop model no.? There is not enough details to pinpoint the problem
Posted on Dec 01, 2012
  • 48 Answers
SOURCE: ethernet port on laptob gateway not working
http://support.gateway.com/support/drivers/search.asp?param=MX6447&st=kw
From a computer that has internet access, download the appropriate ethernet driver for your network card from the link above. As for the recovery disk, you'll have to contact Gateway for a replacement disk.
Posted on Apr 14, 2009
leecom72
  • 4806 Answers
SOURCE: Connect my mediacom cable to a laptop I just
Hi there.
If the other computer is connecting fine then the problem lies with your laptop, possible bad drivers.
This method will hard reset the wireless drivers back to default settings.
What i want you to do is right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
keep me informed please as a download of the drivers may be required.
Good luck
Posted on Jun 29, 2009
clickman
  • 93 Answers
SOURCE: Having Limited Connectivity On My Vista Laptop When I Use Dial Up Connection
It may be the speed of your connection....dial up...
Try connecting somewhere else and see what you get...
If that does not work, check your dial up settings....
Posted on Jul 20, 2008
mail2pvs
  • 390 Answers
SOURCE: I need to set up my IP provided WiFi router-modem
first check with the ISP if any DNS server settings or proxy settins are required(but i think you can alternatively connect your laptops these may have ben already set on the laptops but just in case)
now if your ISP accepts you to have more than one connection from the same link then you can connect the connect the cable from the modem to the INTERNET/WAN areas and you can connect the ethernet cables in the ports marked 1,2,3,4
here check that if you are only etting the link on the computer connected to port1 and no connection on the others then make a small adjustment disconnect the cable from WAN/Internet port and connect it to the Port1 and the computers to 2,3,4
now that you are saying that u r not interested in the wifi so it is advisable that you go to the home page of the router and from there to the wireless page and disable the wireless broadcast of the router for safety purposes
this can be changed any number of times back and forth
cheers
Posted on Jul 14, 2009
  • 133 Answers
SOURCE: runs very slow... hard disk constantly running
You need to defrag your drive, make sure no unnecessary resources are running in the background and delete your temp folder as this fills with allsorts of rubbish you do not need and slows the operating system significantly.
Posted on Jan 05, 2010
Toshiba laptop with windows vista disconnecting from internet every few minutes. dial up service. no phone or any other devices connected. modem/ wires fine. i have reset settings many times. it is n
If the modem and line in are OK, change cables and clean Phone line jack connections with alcohol. Look for oxidation on pins or bent, damaged pins.
Dec 01, 2012 | Toshiba Computers & Internet
The network set up just fine, and the adapter connects perfectly to the Netgear wireless network. One laptop connects wirelessly via the XAVN2001 extender, but the other laptop (in the same room) cannot...
Try searching for drivers on the second laptop. also, try updating the firmware of all your networking equipment. those things alone might solve your problem.
Feb 28, 2011 | Computers & Internet
I've currently got an Acer Aspire 6530 with Windows 7 (x64) Professional Edition installed on the system. I am losing connection to the internet constantly, and it takes me 5 or more minutes to re-connect....
If you are using WPA encryption for your wireless connection, try changing your router to WEP encryption for the wireless security. Try connecting again and see if there are any more issues.
Jan 25, 2011 | Acer Aspire 5500 5570-2609 Laptop
R600 - hard drive light flashes at a constant rate
The simplest solution to your problem would be to reinstall Windows Vista after deleting the old version.
Be sure to boot your computer with the DVD in the drive and when it asks if you want to remove the partition, answer YES. Then put in a new partition, format the drive and reload Vista by rebooting your system with Vista in your DVD drive.
You may lose your sound drivers but they can be downloaded from the Toshiba web site.
Just as an afterthought, you should have at least 1 Gig of RAM installed.
Good luck,
BW
Nov 12, 2009 | Computers & Internet
I will lose internet connection after a while
Try this link & download & install usb driver for your model. When it's ready to download, click run and follow prompts. Restart computer after & see if that helped.
http://www.toshiba.com/taisnpd/support/downloads.html
Dec 13, 2008 | Toshiba PCX2600 (c40054) Modem
Pc camera
my pc camre not working
Oct 09, 2008 | Computers & Internet
Pc camera
necesito el driver
Apr 25, 2008 | Computers & Internet
Wireless internet connection constantly disconnects
You may need to reinstall your windows I imagine its xp or restore it one or the other.
Oct 08, 2007 | Averatec 3200 Notebook
Computers & Internet Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
