Question about Sony DAVHDX265 System
Where is the power protection button - Sony DAVHDX265 System
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
There is no buttom for it,If it is on there is a in ternal problem with the amp,
Posted on Dec 02, 2012
How do I reset the protection circuitry on Yamaha RX-A820?
press and hold the 'tone control' and 'info' buttons and press power. This will release the protect. The first thing that show on the display will be the protect code to tell you why it shut down. If it turns right back off, then you most likely have a short in the amp that will need to be repaired.
Jan 25, 2015 | Yamaha Audio Players & Recorders
The protection circuitry has been activated 3 times consecutively and as a safety precaution, capability to turn on the power is disabled.
If there is no apparent cause for the protection mode activating (such as shorted speakers, burning smell, blown fuses, lighting strike or mains power surges), reset the protection as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
Apr 20, 2012 | Yamaha RX-V671 7.1 Channel AV Receiver
How do I reset my yamaha rx-v671 receiver?
I dont know how to delete a protected picture off my canon power shot a470 camera. Can you help?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Jan 20, 2011 | Canon PowerShot A470 Digital Camera
TV will not come on either with remote, or manual power button. Power button flashes twice & goes out.
The tv is gone into protection mode, try this,unplug it and wait a full 4 hours, then try it again. This may clear the protection fault......hope this helps....
Mar 12, 2010 | RCA G35831AT 35" TV
Help
Take every single cable out of the unit, now power on the unit.
If the power protection still shows then there is an internal fault, usually a short or a component defect.
If it powers on ok, switch off and insert 1 speaker at a time and power on the unit until the protection mode comes on again, the last speaker you have put in has overloaded it for some reason, also as you are trying each speaker use the volume and bass controls to see if there is an internal overload.
Thats as much as I can offer you until you narrow the fault down to the unit or one of the speakers.
Cheers
May 13, 2008 | Samsung HT-X40 System
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Mar 01, 2008 | Samsung HT-X40 System
Kenwood in dash cd player
The protection function is activated when the speaker wire has a short-circuit or touches the chassis of the vehicle. Wire or insulate the speaker cable properly and press the reset button. (The reset button is that little pinhole button below and to the right of the volume control). If you do this and the "PROTECT" code doesn't disappear, you'll have to consult a service center. Further, if you had this professionally installed, they should be obligated to fix the issue for you (hopefully).
Jul 23, 2007 | Kenwood KDC-MP205 CD Player
Sony lbt-x5g500
Power protect tends to mean the main power amp chip has "blown" and needs to be replaced. It only costs about 20 dollars (10GBP). If you are handy with a soldering iron it is easy to do (after you get the thing to bits !) It is the big black thing on the big heatsink inside. The Sony part number is STK442 - 130. Seems a waste to throw the whole thing away for the sake of 10 pounds !. Hope this helps. Nik Howell (nh@totalise.co.uk)
Oct 13, 2006 | Sony LBT-XG500 Shelf System
Sony DAVHDX265 System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
