How to Format hard drive - Computers & Internet
  • 34 Answers
Select the disk (c,or d etc)in hard drive that u want to format.
thenright click on it.
u will see format option
click on it
then click yes and the format will start.
Posted on Dec 01, 2012
Trying to format my hard drive and out of no where it is saying Can not format media is write-protected?
Use a program called Active Kill disk it is a free download this will wipe the hard drive clean every partition will be wiped clean just like from the factory it will then be like installing a new hard drive. Remember to rate my solution.
Apr 28, 2012 | Toshiba MK3265GSX 320 GB SATA Hard Drive
I have Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive bios is detected but we cant format
If the operating system can't format the hard drive then the chances are that the drive is either failing or Failed.
Mar 19, 2012 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
How do I erase all data on my external hard drive?
depends on the erase you want to do. if you want a simple format just open my computer
right click the drive and hit format. select Quick format and then click the format button.
Apr 22, 2011 | Computers & Internet
How do I format this hard drive to a FAT32 hard drive?
Go to My Computer, right click on the drive, go to format. select fat32 on the type list. Remember that this will delete all of the files on the Hard Drive.
Mar 03, 2011 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Hard drive asks to format. but if i format, it will delete all of my documents on the hard drive
Plug that hard drive into another competer as a secondary hard drive and you should be able to save any documents or files you need. While its plugged into another computer you mat as well use that computer to format it. Just open my computer or computer and right click that drive and select format. I would choose the NTFS option and full format. cheers and plz vote
Jan 26, 2011 | Hitachi Computers & Internet
How I can format muy new hard drive in Windows 7
Hi, you should not need to format your new hard drive, they arrive ready to use. If you require the format just plug you device in, go to hard drives where there is an option to format or repair
Jul 04, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
How to format IDE hard drive?
This drive is an IDE drive. The jumpers can be set on it to make it a slave.
Once set as a slave, you can identify the drive letter given to this drive and format it either at a command prompt: C:> format [drive:] /s (to make it bootable) or no /s to just format it.- OR within Windows: right click on the drive letter and select format.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
My SmartDisk 80 gb FireLite hard drive says it is full but it is empty. What could be the reason for this and how would I format it? I use a Macbook pro. I dont want to have to buy a new external...
You will receive an error message when copying a file larger than 4GB to the hard drive if the drive is formatted FAT32. The FAT32 file system has a file size limitation of 4GB. You may also receive an error when backing up to the hard drive using backup software. To correct this problem you will need to format the drive to NTFS. If you are using Windows ME or 98SE, you will not be able to use NTFS.
There are some products that do not support the NTFS files system or changing their file system. If you own a FlashTrax/FlashTrax XT/FotoChute/PhotoBank/USB FireLite XPress, you cannot change the format of the drive to NTFS. It must be kept as FAT32 in order to operate properly. If you are using SOHO NAS via ethernet, do not format it to NTFS. If you have any questions, please contact technical support before you format the drive.
Warning: Formatting a hard drive erases all data from the drive. Please backup any data prior to formatting the hard drive.
To format to NTFS, open My Computer.
1.Right-click on the Verbatim hard drive, left-click on Format.
2.Select NTFS as the File System.
3.Place a check in Quick Format.
4.Click Start.
Once the format completes, you will be able to copy files larger than 4GB to the hard drive.
Feb 03, 2009 | SmartDisk FireLite 80GB 400Mbps FireWire...
How can i format my hp desktop??
Well there are a couple different solutions. If you have another hard drive replace it with your other one and make the one that you want to format the secondary hard drive. Then after you boot the computer, all you gotta do is go to my computer and which ever drive the hard drive is set up on you can right click on the right drive. Go to where it says format and click on it and then follow the instructions.
You can also format the hard drive if you got a windows disk. Just put the disk in your cd-rom and restart the computer and then go through the setup process. You will get to a point where it will ask you if you wanna keep the files the same or do you wanna format the hard drive. There are two options for fomatting: There is a quick format or a full format. If you wanna totally wipe everything off the hard drive make sure you do the full format. It only takes a little while longer than the quick format process, so you are just better wiping it totally clean and then reboot windows on the hard drive when it is done formatting......
Jul 27, 2008 | Computers & Internet
Hd format
well how you want to format it?
just connect it to a system which have a operating system installed.
right click on the drive and select format.
select the options and click format it will format the drive.
Jan 04, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
