My pc won't star,need help please - Computers & Internet
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 31 Answers
Your MBR (Master Boot Record) is broken, you will have to try a rescue disk or do a fresh install of OS
Posted on Dec 02, 2012
2000 yamaha 1100 v star battery charger hooked up back wards. Bike won't start now
Hi, Anonymous you probably blew the main fuse for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Installed battery the WRONG way now bike won start
Put the jumper cables on wrong bike won start 2012 CBR250r motorcycles
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarOwner%20Manual.pdf
May 11, 2014 | 2000 Yamaha V Star 1100 Classic
V star 950 won't start
Hi, Joe you may have fried the ECM while trying to jump it from the Jeep otherwise the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
VStar 650 won start
Frustrated Yamaha Star Won x27 Start
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
YAMAHA XVS950A Owner Manual
May 31, 2013 | 2011 Yamaha V Star 950
My computer won't boot from the screen asking for a choice to safe star
Do you have A INSTALLATIONDISC.Place it computers cd player.and let Windows start from it.and repair the computer.if no disc try F8 .F10.or DEL depends on computers manufactor.it should have have a partition for repairs.chose startrepair.
Mar 29, 2013 | Computers & Internet
How do i know if starter solenoid is bad on my 04 vstar 1100
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Won start crank once and solenoid click Please help
Re Possible starter relay solenoid bad Road Star Forum Yamaha Road Star
Yamaha XVS1100 Service Manual
Yamaha XVS1100R Owner Manual
Jun 12, 2012 | 2004 Yamaha V Star 1100 Silverado
Yamaha royal star xvz 1300 won't idle without choke
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
2003 Star 1100 Custom won idle without choke aftermarket exhaust
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
https://www.tradebit.com/filedetail.php/243740175-1996-2001-yamaha-royal-star-xvz13a-service-manual
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
Jan 01, 2012 | 1996 Yamaha Royal Star XVZ 1300 A
Lg 2242 won t display widescreen full resolution
the FX5200 doesn't support that resolution. You will need to buy a card that supports 1680 x 1050
http://support.dell.com/support/edocs/video/p57010/en/usage.htm#display_modes
Feb 05, 2009 | Star Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
