Question about Whirlpool Dishwashers
Whirlpool quiet partner II dishwasher remove filter
I want to remove debris from the filter and can't remove it.
SOURCE: Dishwasher (whirlpool quiet partner II)
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
Posted on Sep 09, 2008
SOURCE: Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Posted on Nov 23, 2008
SOURCE: whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Posted on Jan 22, 2009
WRMtech
  • 70 Answers
SOURCE: RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Posted on Mar 22, 2009
jsrock516
  • 5911 Answers
SOURCE: clean light is flashing
This can be a common issue with some Whirlpool manufactured dishwashers. This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Nov 02, 2009
Testimonial: "Worked perfectly! Thank you."
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner ii dishwasher has quit working. Power is getting to the dishwasher but it is not coming on at all. There is water standing in the bottom of it and a very foul smell is present.
This dishwasher has a thermal fuse that attaches to the main control board that may have failed, it can be tested with a meter for continuity if it does not have continuity then it is your problem.
Apr 21, 2012 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
I have a whirlpool quiet partner II dishwasher. There is a gritty residue on the dishes in the top rack and on some of the silverware. Any suggestions on how to fix this?
MAKE SURE THE UPPER WASHER ARM IS NOT CLOGGED, SOMETIMES FROM DETERGENT BUILD UP IF YOU'RE USING POWDER DETERGENT. CHECK ALSO FROM THE BOTTOM IS THERE'S ANY DEBRIS THAT MAY PREVENT THE WATER GETTING TO THE UPPER WASHER ARM
Jan 16, 2010 | Whirlpool Dishwashers
My Whirlpool quiet partner dishwasher seems to run
try a large cresent wrenck,or channel lock plier.ps.might place towel over plastic nut,to protect from wrench damage.
Oct 10, 2009 | Dishwashers
Quiet partner ii just stopped
Most likely it has an internal fuse or relay gone bad. Check the curcuit w/ a "glow stick" power identifier available at Lowes or Home Depot.
Aug 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
235 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
