I picked up a Mitsubishi Model No. WD- 62527. The guy said all it needed was the lamp replaced, I replaced it and the tv still doesn't turn on. Their is a green light that blinks were it says timer for about a minute then the orange light under lamp turns on. About a second later the green light under timer blinks three times then turns off and then the only light on is the lamp orange light. It will continue to do this hole scenario over and over again...HELP!
3 Suggested Answers
techman007
  • 1112 Answers
SOURCE: WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Posted on Nov 28, 2009
SOURCE: I have Mitsubishi WD-Y57 DLP.
I have the same TV. Mine is almost 3 years old. From what I've learned you should try to reset the TV. There is a small button in the front input compartment. Use a pen to push that in and wait for the green light to stop blinking. Then try the TV.
If that does not work you probably need a new lamp. Apparently the lamps only last for a couple years on average. Having to replace them can really add to the cost of buying/owning one of these TV's
Posted on Dec 01, 2009
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
Mitsubishi wd 62527 blinking status light what can I look at? No Picture, Flahing TImer light goes off agter 2 min then tv turns off and if you power it on it flases Lamp and Status multiple times?
This is a common issue with bad capacitors in the TV. You can call in a shop or repair it yourself. You can google the parts using this number Z1234TV
Mar 31, 2012 | Mitsubishi Televison & Video
I see no picture
Televisions covered: Mitsubishi DLP High-Definition Televisions:
C Series: WD-60C8, WD-65C8, WD-73C8
735 Series: WD-60735, WD-65735, WD-73735
736 Series: WD-65736, WD-73736
835 Series: WD-65835, WD-73835
Here's an online version of your televison's (94 page) "Owner's Guide":
http://www.mitsubishi-tv.com/pdf/ownersguides/WD-60735.pdf
It sounds like the lamp in your "Mitsubishi Lamp-Cartridge" blew.
If your TV remains under warranty, you'll want to call Mitsubishi at 1-800-553-7278, and you'll need to have (a) Mitsubishi Model number, (b) serial number, (c) TV purchase date, and you'll have to ship the old lamp module back to Mitsubishi so that:
"All lamps replaced under warranty must be returned to Mitsubishi where they will be inspected for defect verification."
Return old Lamp-Cartridge to:
Mitsubishi Digital Electronics America
1001 Cherry Drive, Suite 2
Braselton, Georgia 30517
If you have trouble finding your TV's information, you need better "Warranty Management". Warranty Management can be done with software, or on paper. You may even choose to toss all your Owner's Manuals into a box, with the receipts. In case anything malfunctions/needs to be reprogrammed/reset then the manual & spare parts/cables (in a large Zip-Loc(R) baggie or two) can be quickly located and consulted.
If you television happens to be out of warranty, a nice (expensive) new lamp module can be ordered from Mitsubishi by calling 1-800-553-7278, or by ordering online at http://www.mitsuparts.com.
Refer to pages 75-76 of your Owner's Guide for complete Lamp-Cartridge module replacement instructions (with nice illustrations).
Your TV's Lamp-Cartridge part number is: Mitsubishi 915B403001
Here's an online source for the Mitsubishi 915B403001 Lamp-Cartridge:
http://www.dlplamps.com/products/mitsubishi-dlp-lamp/mitsubishi-915b403001.html?gclid=CLzb6ciaiq0CFQdN4AodZkMonA
Note that with the dlplamps.com offerings, you can purchase the lamp only for $109, or the entire lamp-cartridge module for $129. So you can save yourself $20 if you're handy. Remember to keep all fingerprints off the lamp glass element - this small amount of oil will weaken the glass, and cause premature failure of the lamp. In the event that you get a fingerprint on the lamp glass, erase it thoroughly with rubbing alcohol. Alternatively, one may prevent fingerprints with latex gloves (make sure you haven't an allergy to latex, though).
If the reason that the lamp blew turns out to have been a clogged Lamp-Cartridge Filter (once you have the Lamp-Cartridge out of the TV and in your hand, you'll be able to easily see the mesh filter), then place a regular PM (Preventative Maintenance) of this filter on your calendar.
Dec 17, 2011 | Mitsubishi WD-60735 Projection Television
I have a mitsubishi 62 in wd 62527 and the red lamp light came on and we unplugged the tv and reset the red button now no power
The red light usually means the projection lamp is bad. If you replaced it and the set still doesn't come on, then it is likely the ballast that drives the lamp is also bad. Also, if/when you do replace the lamp, make sure the access door to the lamp is fastened in properly. Other possibilities include a cooling fan failure and clogged air vents/filters. If none of these are the answer, then I would suspect problems in the power supply, usually stemming from defective capacitors which will require a technician with soldering skills to check out. Hope this helps.
Jul 10, 2011 | Mitsubishi Televison & Video
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Television
Press menu and the device buttons on the tv both in together and hold them in for 5 seconds and see if the led will blink a two digit error code, then let me know the blinks.
Jul 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
