My laptop keboard is acting up sometime the letters dont want to type.sometime its a letter and sometime its another letter and then sometime it works perfectly
Monda it was the letter N that wouldn't type,then it started to respond .today its the letter y thats giving me problems
You may have unwanted debris under the keys. Turn the keyboard upside down and brush gently between the keys. If the problem then affects another key you know you are on the right track - the debris is moving around.
Posted on Dec 02, 2012
Pyrhyc
  • 2028 Answers
SOURCE: HP Compaq NX960 Laptop Keyboard Problem
This is generally a sensitivity issue with the keyboard. It's usually caused when the rubber depressors that activate each key start getting worn. Sometimes you can take each key off individually, take off the rubber depressor and clean the contact point on the keyboard and up inside the depressor where it makes contact. Clean it with with rubbing alcohol and Q-tips. This is alot of work and only fixes the problem about 60% of the time. Your only other option is replacing the keyboard.
Posted on Jul 23, 2008
  • 916 Answers
SOURCE: the letter L key is not working
Check your regional settings in windows and make sure they are set correctly for the keyboard layout.
Posted on Jun 02, 2009
  • 7993 Answers
SOURCE: My laptop keyboard types two letters at a time.
I am convinced. If the situation were not serious I would say that you invented a new language.
It seems that the letters concerned are aligned in two columns. Possible that the wires are not well electrically isolated. I would suggest you try to clean the keyboard with a soft brush or compressed air. If that does work you should have the keyboard repaired.Was some electolytic liquid (salt water, orange juice) spilled on the keyboard by any chance?
Hope it helps.
Posted on Sep 07, 2009
SOURCE: Slow Keypad with sticking space bar
My MOM Used AOL mail, for her it was the AOL news pictures loading every few seconds in the backround. If you press the pause button in between the left and right arrow boxes in the news box (under the pictures) you will turn off that function, which should speed up your typing, as every time a news item switches it causes a delay which may miss a keystroke, etc.
Posted on Sep 25, 2009
SOURCE: bluetooth activates by itself, random letters appears when typing
it's a hw problem. when i using my easyport iv it doesn't occures. only when the display is turned up. after 2-3 hours of use i think it's overheating. (i tried to buy a waranty extension after i bougth the laptop, but acer said "it isn't available". i think thew know someting about this problem...) i bought it in Jan 2009, and the problem occured in Jan 2010. just after the warranty expired. wierd...
Posted on Mar 14, 2010
On a Generac model 1646-2 generator is the oil level switch normal open with full oil level.
I don\'t know, but change the switch or bypass it. They give plenty of problems & motor would start sometimes & not others.....Check the oil & rely on old style tech. I bypassed the switch on both of mine.after they gave problems & wouldn\'t run when needed....I only got a second one when I needed power & the switch was the only thing wrong ( I found this out too late.) & ended up with 2....
Jun 19, 2014 | Coleman Powermate Subaru 5000W Portable...
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
I have a 1987 Dodge Aries and I'm having problems
There's a bolt and a plate near the bottom of the battery holding the battery in the tray. Did you take that bolt out and lift the plate ?
Jan 03, 2013 | Cars & Trucks
My nokia e7 screen has gone to a black and green glitch back ground
Have you tried a reset by holding the power key down for 10 seconds?If that doesn't work you can try removing the battery for a few seconds.
I had a similar problem with my E7, it was dead and wouldn't respond even when I plugged it into my PC. But once I had removed and replaced the battery it was working fine and its not gone wrong since. Here's a good guide on removing and replacing the battery
Dec 28, 2011 | Nokia E7 (16 GB) Smartphone
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
2 letters get typed while pressing one key for some characters. There are some keys in pairs in which if i type any of the key, both the letters gets typed. i.e. if I type s, sd gets typed or evens if I...
try other keyboard if the problem don't appear that's hardware problem, may be the rubber under the key responding each other, it is easy to open the keyboard casing then you can check the problem inside
May 13, 2010 | Computers & Internet
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
