Question about Husqvarna Sewing Machines
Where is set menu on husqvarna designer SE
Designer SE
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
Viking designer se screen is stuck in welcome screen when turned on. update did not help me! my steps: 1turn on Designer SE le and connect to computer. 2install Designer SE 3D embroidery Software...
I purchased my designer se in 2006, and the frozen screen happened for the first time tonight as I was installing fonts on the machine. I did as suggested...got into update mode and installed the latest update and it worked! Thanks so much. I thought I would have to pay a lot of money to have the problem resolved. I am a happy DSE owner.
Dec 04, 2010 | Husqvarna Designer I
My HP pavillion, window 7 cannot find the designer
You need to reinstall them, they will be on the communication disk that came with your machine or the 4D software cd if you purchased that.
May 21, 2010 | Husqvarna Designer I
UNABLE TO UPLOAD SOFTWARE FOR MY NEW HUSKVARNA VIKING LIMITED EDITION SE
I don't have an SE (I have a Designer 1) but I know uploading the machine software on an SE can be tricky. There are some useful Help files on the Husqvarna website - go check them out and see if that solves your problem.
Nov 17, 2009 | Husqvarna Designer I
Have a Rose Husqvarna sewing machine and just purchased a Designer SE. Purchased a Rose reader writer for my cards and want to put them on the computer to use with my Designer. Can not find any...
If you bought your SE from a dealer they will be able to transfer those designs for you. If not, you need the Husqvarna Viking software so you can "read" the designs from your rose cards into your computer, then you will be able to send them to your USB stick for the SE.
The software really unlocks the potential for that machine. The first module of the software is about $400, comes with about 100 fonts and many designs and abilities to alter the text you want to sew. If you go up to the $900 option, you can cut designs apart and save different aspects of the design by themselves and also get an automatic digitizing option that works well. Husqvarna's web site shows their software in detail.
Oct 08, 2009 | Husqvarna Rose
Viking Designer SE missing the spool holder where can I buy one?
some authorized husqvarna viking dealers have websites where you can order the spool holder. Might just call an authorized dealer and purchase over the phone. Other 3rd party vendors are http://www.pd60.net and http://www.sewingpartsonline.com may have these. Hope this helps.
Mar 14, 2009 | Husqvarna Viking 1
Designer 1 touch screen freezes
Static Electricity and Designer 1:
The designer 1 is susceptible to static electricity. They sell static removers for electronics. Try that 1st. Don’t spray your machine, just the rag and wipe the machine. Endust for electronics makes a pump spray and you can even use it on the screen (DONT spray the screen). Then try to recalibrate the screen in the set menu. If you can’t get into the set menu keep trying until you can otherwise, there is a way to get into the service mode to set it.
Feb 25, 2009 | Husqvarna Designer I
Service Menu For Husqvarna Designer SE
Hold down the start button and the presser foot pivot buttons at the same time and turn on the power. The machine will make a funny noise and the test screen will come up. You then need to find the sub-menu, I think it says tensions on it but I'm not sure.
Jan 31, 2009 | Husqvarna Designer I
Sewing Machines Logo
85 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
