Question about Wildgame Innovations WGI N4E DIG CAMERA IR 4C 4MP
Can see picture from flextime - Wildgame Innovations WGI N4E DIG CAMERA IR 4C 4MP
How do I get pics of off camera when it has no sim card in it
The camera came with a CD. On it is the software you need to retrieve the pictures. But I don't think there are any on the camera, if you did not insert a memory card.
Perhaps one or two, but certainly not tons.
Before you use the USB cable (came with the camera too) to connect the camera to the computer, you have to install the software from the disk on your computer. After installing the software you can connect the camera and the computer will recognise the camera. First time give it a minute or so, because the computer needs to install and start a program.
Nov 21, 2014 | Wildgame Innovations Red 6 N6E 6-Megapixel...
Acer i cant change my profile picture in badoo pleas help
for example I have 15 pictures to choose for profile picture in my album,and when I delete that picture who was on my profile pic badoo automatic takes next picture who was next to deleted picture,so I put picture which I want next my profile picture and when I deleted pic. I got my favorite picture for profile,and after that I was add again that picture which I was deleted and she is in album again :D (with mouse you can sort picture how you want),so with mouse you can put favorite picture in front of existing profile picture and when you delete that existing picture you favorite automatical set for profile picture
Sep 05, 2011 | Acer Aspire 3623WXCi Notebook
How do you set the background on a Dell to show a slideshow of all of the pictures?
To use your own pictures
1.
Find the pictures that you want to include in your slide show. All of the pictures must be located in the same folder.
Open Desktop Background by clicking the Start button Picture of the Start button and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
2.
If the pictures that you want to use aren't in the list of desktop background pictures, click the Picture location list to view other categories, or click Browse to search your computer for the folder where the pictures are located.
Picture of the Picture location menuLook for pictures in other locations on your computer.
3.
Select the check box for each picture that you want to include in your slide show.
By default, all of the pictures in a folder are selected and will be part of the slide show. If you don't want all of the pictures in the folder to be included, do one of the following:
Clear the check box for each picture that you want to remove from the slide show.
Picture of one check box cleared in a group of selected photosClear the check box to remove a picture from the slide show.
Press the Ctrl key, and then click each picture that you want to remove. Only the selected pictures will appear in the slide show.
To create a slide show of pictures on the desktop, you must select more than one picture. If only one picture is selected, the slide show ends and the selected picture becomes the desktop background.
If all of the pictures in the folder are selected, any new pictures that you add to the folder will be added to the slide show automatically.
4.
Do one or more of the following:
Click an item in the Picture position list to crop the pictures to fill the screen, fit the pictures to the screen, stretch the pictures to fit the screen, tile the pictures, or center the pictures on the screen.
Click an item in the Change picture every list to choose how quickly the slide show changes pictures.
Select the Shuffle check box to have the pictures appear in a random order.
5.
Click Save changes.
To use pictures that Windows provides as part of a theme
1.
Open Personalization by clicking the Start button Picture of the Start button, and then clicking Control Panel. In the search box, type personalization, and then click Personalization.
2.
Under Aero Themes, click a theme to apply it to the desktop. With the exception of the Windows 7 theme, all of the Aero themes include a desktop background slide show.
3.
To change the theme's default slide show pictures or settings, click Desktop Background.
4.
By default, all of the pictures associated with a theme are selected and will be part of the slide show. To add pictures from other themes to your slide show, do one of the following:
Point to each picture that you want to add to the slide show, and then select its check box.
Picture of one check box cleared in a group of selected photosPoint to a picture, and then select its check box to add it to the slide show.
Press and hold the Ctrl key, and then click each of the pictures that you want to add. Only the selected pictures will appear in the slide show.
5.
To change the slide show's settings, do one or more of the following:
6.
Click Save changes.
Your slide show will be part of the unsaved theme that appears under My Themes.
For information about customizing and saving themes, see Create a theme.
You can find more themes to add to your collection in the Personalization Gallery on the Windows website.
For information about customizing a desktop background slide show, see Make changes to your desktop background slide show.
Aug 04, 2011 | Computers & Internet
How to edit my profile picture on my facebook?
Click the edit my profile picture (beside the picture)in your facebook homepage,
> Click the profile picture, after clicking, select picture or browse can be seen on the page
> Browse picture in your computer to change or edit your profile picture, then click view profile, your profile picture already have new picture
Nov 11, 2010 | E-Machines M2350 Notebook
How do I copy pictures from a USB port to the memory in the Digital Picture frame?
it depends on your digital frame becuase some frame cannot be save the picture on the internal memory. if the manual says that you can save or upload try to go setting and look for copy then choose from( memory card to internal or internal to memory card)
goodluck my friend
Jul 13, 2010 | Smart Parts Digital Picture Frame
G1 Pictures Messaging
It should be picture size issue. -Take a Picture -Open the picture in the picture browser
-Crop the picture (Can select the entire picture if so desired)
-Save
-Send the newly cropped picture in an MMS . Downsizing the image to 50-60kb. . should work.
Apr 02, 2010 | HTC G1 Smartphone
No picture in a picture
The picture for picture-in-a-picture must come from somewhere. Try a DVD for the picture in picture. It may be the second tuner for the picture in picture that has failed.
Mar 30, 2010 | Hitachi 50UX26B/27K 50" Rear Projection...
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
I cant figure out how to get my pic on facebook i tried, tried
Step 1
Locate a picture that you want to be your profile picture.
  • Step 2 If the picture is already on Facebook, click on the picture. In the lower righthand corner, you will see a list of possible actions. Click on "Make Profile Picture". The website will prompt you to crop the portion of the picture that you want to be your profile. You can either: 1. Drag a corner of the small cropping box to make it bigger or larger to include a section of the picture OR 2. Drag all corners of the small box to all edges of the picture. Option 2 will select the entire picture. Option 1 is useful if, for example, the picture includes you and two friends. You can just crop the part of the picture that includes yourself and make that your profile picture. Both of the options will resave the cropped images in your "Profile Pictures" folder.
  • Step 3 If the picture is on a website, save it to your computer in a folder/ file location that you will be able to easily locate. Once the picture is saved onto your computer, login and go to your Facebook profile. Click on your profile (default) picture. On the page that comes up, above all of the thumbnails, you will see "Edit Photos" / "Change Profile Picture". Click on "Change Profile Picture". On the next page, click "Browse". Find your picture and click on it. Check the box that says you have the rights to the picture, and click on "Upload Picture".
  • Step 4 You can also select a portion of your profile picture to be your thumbnail picture. This is the picture that comes up next to your name on chats, mini feeds, and applications on Facebook (such as "Lil Green Patch"). Generally, it is the middle of your profile picture, but you can adjust it as needed.
  • Oct 20, 2009 | Computers & Internet
    Pictures Remaining number change after I take a picture
    The file size of a picture depends on the resolution you choose and the complexity of the scene. A picture of blue sky has a smaller file size than a picture of autumn leaves. If the Pictures Remaining number does not change when you take a picture, it generally means that the picture does not take up sufficient memory to decrease the number. This is normal. The number is not a count of consecutive pictures; it is counting available space - the approximate number of pictures remaining.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Wildgame Innovations WGI N4E DIG CAMERA IR 4C 4MP Logo
    Top Wildgame Innovations Video Cameras Experts
    Are you a Wildgame Innovations Video Camera Expert? Answer questions, earn points and help others
