Question about Panasonic Toughbook 19 Notebook - CF-19CHGACJM
DOES THE PANASONIC TOUGHBOOK CF-48 HAVE A WIRELESS SWITCH SOMEWHERE?
  • Panasonic Master
  • 7,627 Answers
SOURCE: Install XP on Panasonic Toughbook CF-27 ?
sxcss
Posted on Apr 30, 2008
SOURCE: Panasonic CF-51 Toughbook Fn keys don't work at all
The following website contains the needed drivers:
https://eww.pavc.panasonic.co.jp/pc/cgi-bin/itn/toughbook/dl01.cgi
Select your model of CF-51 Toughbook, but you MUST be specific. There are about nine variations of the CF-51 so you must use the right drivers.
Download the hkeyapp, hkeyset, and hotkey files and unpack all files. Use the default unpack locations. If you download the files for a laptop version that is not your own, when you try to run any of these files the computer will tell you that the file is not for your model. If the files successfully unpack then you know you have the right files.
For hkeyset and hkeyapp you must run the set-up applications in the unpacked folders.
Go to Control Panel>System>Hardware>Device Manager and go to Other Devices.
The Hotkeys will appear as an "Unknown Devices" so if there is more than one, right click and choose "Update Driver".
Select "Install driver from specific location" and direct it to "C:\util2\drivers\hotkey" folder.
The computer will find the file and install the driver after which point you must restart the computer.
Hope this helps. It took me a while to figure this stuff out on my own so hope it speeds up somebody else's attempt.
Andrew
Posted on Dec 25, 2008
1234s282
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Posted on Jan 04, 2009
leecom72
  • 4806 Answers
SOURCE: panasonic toughbook model number
Hi there
Download drivers for both if you are unsure, one way to tell if its a MK1, look underneath the laptop at the model number, if is says neither MK's its MK1 as it will say if its a MK2.
Saying that the drivers should work on both machine models
Good luck and kind regards
Posted on Jan 19, 2009
1alexh
  • 484 Answers
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Posted on Jun 22, 2009
Where is the wireless swith on the cf-19
The wireless switch is behind the PC Card Door located on the left side of the Toughbook 19
Rugged Mobile Technology Panasonic Toughbook Toughpad Tablet Sales...
Jun 16, 2014 | Panasonic TOUGHBOOK CF-18 Tablet PC
Turn wireless lan
On page 75 and page 76 of the Reference Manual
for the Panasonic Toughbook CF51 is described
the procedure to turn "on" the wireless lan:
1 Double-click on the taskbar.
2 Select your wireless LAN adapter and select [General].
3 Select [On] for [Switch radio].
4 Select [Networks] and select [Add].
5 Enter the profile name and network name (SSID), and then make
other necessary changes, then select [Next].
6 Make necessary changes and select [Finish].
Please note that there is no Physical Wireless Switch
on the Panasonic Toughbook CF51.
You can find the manual here and double-check yourself:
https://panasonic.ca/PCS/OperatingInstructions/CF51MK1_X_E_Reference_Manual_A.pdf
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jan 22, 2014 | Panasonic Toughbook CF-51 Notebook
Cf-48 I need nic drivers to hook to internet
http://www.toughbookdrivers.com/drivers/cf-48/ check this out. . .
Oct 22, 2012 | Panasonic Toughbook 48 Notebook
Wireless connectivity
possible reasons that it is "off"
Physical switch on outside of case that has a turn on and turn off function. Make sure this is turned on.
Go to network places and find the connection that says wireless (or something similiar), it should say Enabled, if not then enable it.
Jun 21, 2009 | Panasonic Toughbook CF-51 Notebook
No sound cf 48
download Astra software...run it on your computer.....you will get information of all devices through this software.....check the chip set manufacturer and the number for the chip set do a google search for that particular audio driver chip set you will be good to go
Nov 10, 2008 | Panasonic Toughbook 48 Notebook
Urgent help needed
Dear Ali,
you can download the drivers for your Toughbook , from this site:
Cheerup and be Happy always
Mar 28, 2008 | Panasonic Toughbook 48 Notebook
Help
Panasonic wants you to register with their site before you get access to their drivers.
You can register here and then you should be able to download your drivers from them.
Nov 15, 2007 | Panasonic Toughbook 48 Notebook
Panasonic Toughbook 19 Notebook - CF-19CHGACJM Logo
1,341 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
