I have the mobo ibm thinkcentre M50 8219 I have a new case
But I want to connect the hdd led, reset, power led, etc to this ibm mobo but where is te connectors in the mobo? thanks!!!
  • 3,606 Answers
Hello i depends on the manufacture of the mainboard.
The pinout for the frontpanel is placed down low in the right corner of the mainboard.
Here are the most used pinout:
I have the mobo ibm thinkcentre M50 8219 I have a  - 12_2_2012_11_14_23_am.jpg
12_2_2012_11_15_01_am.jpI have the mobo ibm thinkcentre M50 8219 I have a  - 12_2_2012_11_15_22_am.jpg><br><img src=
Good luck
Posted on Dec 02, 2012
bluegreenash
  • 661 Answers
SOURCE: Front Panel Connector
There should be a Front panel block on the motherboard
you should connect to it like this
Posted on Nov 15, 2007
map9966
  • 2351 Answers
SOURCE: Front panel connections
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Mike
Posted on Nov 30, 2008
VooDooNOFX
  • 95 Answers
SOURCE: Connection to Motherboard P4IBMS
You can download a PDF of the manual here:
http://www.ecsusa.com/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=74&areaid=2&LanID=9
I have blown up the image for you to see it easier:
good luck
steven
Posted on Sep 17, 2008
ChipcircuiT
  • 157 Answers
SOURCE: How to connect Power LED, Power SW, Power Reset and HDD LED
it is written in the motherboard..
re-reset botton
pw- power botton
hdd led- hard disk led
pw LED- power led
the code is pin 1....
Posted on Jan 28, 2009
  • 3 Answers
SOURCE: I just installed my motherboard samsung harappa-4
LOOK FOR THE FRONT PANEL PIN HEADER.
IT MUST BE SOMEWHERE BY THE EDGE OF THE MB.
THERE ARE MARKINGS LIKE HDD LED, PWR SW ETC.
HOPE THIS HELPS.
Posted on Apr 14, 2010
Pin connection front panel power switch
The only place to get it is from IBM, as it was designed specifically for them to go in their ThinkCentre A50 line of computers.
The link for the User's Guide, which is what I presume you need, is:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55533
If, instead, you want the Hardware Maintenance Manual, it can be found at:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55532
Finally, if all you desire is the Quick Reference, go to this link:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55534
Now, just to be complete, though I doubt this would do anything to help you, here is the Setup Poster:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55595
Jan 03, 2013 | Lenovo D865gkd Ibm Motherboard Mpga478b
IBM 8123 not powering on the problem is the start up fan is running continuously.
Hello Dear,
If the Startup FAN is running, means the Power is going to your motherboard and other components. SMPS seems OK. You should check the display cable and CMOS Battery.
Just try to pull out the battery and Make the machien switch ON. (Don't forget to Check the display cable is connected or not).
If it is then means your CMOS battaery is faulty one.
WIth regards
FIXYA team
Oct 09, 2010 | IBM ThinkCentre M50 8187 Desktop PC -...
Dell Asus M2N61-AX MB front panel connector Nix ATX Gaming case
I assume you mean the HDD,reset,on switch etc where they plug onto the mobo.
Most mobos are labelled on the board but you will need good eyesight to read. They are labelled HDD, RESET, SPEAKER etc.
If not simply look up mobo manual from vendors site. You will need the DELL serial / part number from the old unit though.
Apr 29, 2010 | ASUS Computers & Internet
E210882 socket type 775, PCIe, DDR2 - Will not turn on
On the Dell board, the
CORRECT pinout for J8H1 is as follows:
1-3: HD LED (#1 is +)
2-4: PWR LED (#2 is +)
5-7: PWR ON/OFF
6-8: RESET
5,16: +5V
10,11,14,15: not connected
12,13: GND
Regards.
Jul 27, 2009 | Dell (E210882) Motherboard
Compaq for Evo D300 Motherboard
The manual can be found here. There is a numbered diagram inside. http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html Hack
Jul 09, 2007 | Compaq (281946-001) for Evo D300...
Computers & Internet Logo
1,136 people viewed this question
David Payne
David Payne
