Question about Hoover F7431-900 SteamVac Vacuum
Where does the suction hose hook to - Hoover F7431-900 SteamVac Vacuum
    Guru:
  • 887 Answers
That depends on how much fun you want to have. But, it usually only fits in one place.
Posted on Dec 01, 2012
Why does my machine vacuum has very little suction while the there is no solution come out of the hand hose?
Make sure you have the hoses hooked up properly. Also check that there is no obstruction/blockage in the hose. Otherwise, contact your friend.
Apr 26, 2016 | Vacuums
No suction in hose
Remove the machine side of the hose--is there suction at the machine? If so, run a broom handle or similar through the hose to dislodge the clog. If no suction at the machine, you may need to fish out debris with a hooked stiff wire from the port. Remove the bag and examine the port area underneath for similar clogging. Finally, check the brush area underneath the machine bottom plate for more obstruction. Also, check the brush assembly for debris accumulation. Remove the drive belt and check for free turning of the brush. If turns hard, remove the brush, clean the bearings and roller pins, then apply a small quantity of light oil like 3-1 or sewing machine oil. Hope this helps!
Jun 20, 2010 | Lindhaus 380 Diamante Bagged Upright...
HOSE HAS NO SUCTION - VACCUM WORKS JUST FINE - DC14 MODEL
Hi
There must be a blockage in the hose.
Check the hose from the pickup,just behind the rotating brush all the way to the dirt collector.
Push a length of wire with the end bent into a small hook(similar to a fish hook) to pull out any blockage.
Regards
Phillip
Oct 16, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater attachment has no suction.
Your hose issue is isolated from the garage. You have a switch problem in the handle of the hose.
If the hose has a swivel handle your problem will lie in the switch itself or the contact rings within the lower portion of the handle itself. If this is a light gray hose with swivel handle several years old switches were an issue from time to time . The problem can normally be fixed by replacing the internal wiring harness in the hose.
Oct 03, 2009 | Easy Flo EF1600 Central System Vacuum
Suction when I vaccum the floor but not in the hose
remove the filter from the dirt cup and try again,if you have suction the the filter is clogged.the other is the intake hose that goes into the top of the base where the clear tube is.disconnect the hose from the base tube and take a coat hanger and bend the end into a hook.open the litte flapper door and stick the hanger down in the tube and see if you can pull out a clog of dirt.last but not least,disconnect the top hose completelyfrom the vacuum and see if you can blow through it.if you can't then the flex top hose is clogged.open the little flapper door on the top of the base and turn on the vacuum,if the intake hose isn't clogged then you should have suction.that will tell you that the broblem is in the flex hose or the filter
Jun 07, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Hoover tc5238 bagless cylinder vacuum cleaner - no suction
You have a clogged hose. Sometimes a Q-tip or something like that gets sucked up and then stuff jams up against it. You can use a long stiff wire with a hook bent in the end to reach the jam and work it loose. Just be very careful not to poke the wire through the hose! Work slowly and get the clog out a bit at a time.
The clogged hose would also account for the red light.
Apr 08, 2009 | Vacuums
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
I have little suction when using the hose attachment
Check the hose for a blockage. If you remove the hose, if there is suction at the point where the hose hooks to the back of the vac, then the hose is clogged. If no suction there, check filters, make sure they are clean.
May 31, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Reverse Suction
You have a clog either at the inlet by the brush roll or in the hose. Pull the hose and check for suction at the end of the hose, If it is ok there, then you have a clog from where the hose hooked into and the inlet at the bottom. If at the end of the hose there is no suction, take the hose off and see if you see a clog in it. If no clog there, then check all filters, if they get clogged, then air can't flow thru them and no suction.
Dec 31, 2007 | Hoover U5507900 Elite Rewind Bagless...
Upholstry attachment
Check to make sure that the hose hasn't cracked, where it hooks up near the motor. If so, replace the hose.
Nov 11, 2007 | Hoover F5906-900 Upright Steam Vacuum
Vacuums Logo
27 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
