Question about Olympus TOUGH TG-310 Digital Camera
How do i turn off the write protect?
My camera is locked i see a picture of a key what do i need to do to turn it off.
    Guru:
  • 887 Answers
Did you try the "off" switch?
Posted on Dec 01, 2012
  • kuzzia83
    kuzzia83 Dec 01, 2012
    yes like 10 times...
I want to delete protected pictures
If the picture on the camera is protected, unprotect the picture first. In playback mode, scroll to the protected picture, then press the AE-L/AF-L button on the back of the camera.
If the memory card is protected, take the card out of the camera. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 20, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
How do i turn off "File Protect" and be able to delete again. It won't let me delete pictures and there is a little animated figure on the print that says digital camera out to the side with...
You have accidentally selected lock option.You need to select unlock option for the same. Press the menu button and then press right/left button to select the protect menu. Then you need to select unlock and that would turn off file protect.
Kindly accept the solution so that i could get the credit for my time.
Thanks and Regards
taran_2005
Jul 11, 2011 | Vivitar Cameras
When i turn my camera on it says protected card and cannot take pictures
The card is locked, usually found on the left hand side of card, push the yellow lock key forward to release lock, reinsert in camera, switch on and you should find no further problem.
Nov 13, 2010 | Fuji Rod Repair Kit
My picture card is saying no picture when i go to take a picture the card says full it wont let me take a picture??
Hi.
Check AE lock custom button:
Ensure that the memory card has no protective seal or object in front of the protection area. See here.
Ensure that the files are not individually protected (Key sign in settings)
If that does not fix the problem, then the card may be defective. In that case replace the card.
Here a manual.
Sep 14, 2010 | Olympus Camedia C-3020 Zoom Digital Camera
HOW DO I UNLOCK PROTECTED PICTURES IN MY CAMERA
Press MENU to enter the menu. Select the SETUP menu (the wrench icon). Select Protect (the key icon). Protected pictures are indicated by a little key icon in the upper-left corner of the picture. Navigate to the protected ones and press up/down to unprotect.
Or is the entire card protected? SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 17, 2010 | Nikon COOLPIX L18 Digital Camera
How do I delete pics in a protected file on my sony camera
There are two ways to delete the protected files.
1. Formatting the internal memory or "Memory Stick Duo" erases all data stored on the recording media, even if the images are protected, and these images can not be restored.
2. Just select the protected sign (key) to turn it to gray from green. Then press OK button shown in the below figure. The center button is OK. If you press again, it turns to green to protect your file. Press again to unprotect it.
That is all.
I hope this helpful.
Jun 01, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
The camera file is locked
not sure what you are asking? but most cameras have a little key picture on settings or pback of camera, if you want to protect photos from accidental erasure you push that button and it locks the file, when you view photo on camera it will show a little key in upper right corner of the picture. just a shot
Dec 28, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Help
Check make sure you did not lock the pictures.
You can lock through playback menu settings or from quick key (little lock key on camera).
Also some mem cards have a little slide lock to protect images from being erased.
Hope this helped. Good Luck! enjoy your trip. Need more help comment back.
Mar 13, 2009 | FUJIFILM FinePix S100FD Digital Camera
Picture lock
Protected pictures cannot be erased using [ERASE],
[SEL. IMAGE] or [ALL ERASE], but they are all erased by
formatting.
• Go to Playback mode in the camera. Select the picture to be unlocked with the left or right arrow buttons, and to remove the protection select OFF with the up or down arrow button.
Dec 19, 2008 | Olympus FE-220 Digital Camera
What does write protect mean?
"Write Protect" means that something is locked and your device (camera) cannot "write" to it's storage area.
What type of "storage media" are you using?
For example:  the camera's internal memory, a CompactFlash card, a Memory Stick, an "xD-Picture Card" (micro, mini or regular sized), or a Secure Digital/MultiMediaCard.
[Did you put something  (a small plastic card of some sort) into a slot on the camera before or after turning it on?
Those little cards usually have a tiny button (also called a switch or lever) on them that will move back and forth to lock (write protect) or unlock it. This sounds like the memory card inside your camera is locked or "Write Protected.
To fix this simply take it out, closely examine the memory for the button- the button will be closer to the word "lock" or "protect" and all you need to do is gently slide it in the opposite direction from where it currently is. Put it back into the camera and see if it still says "Write Protect."
Let me know...
Rae
Nov 27, 2008 | GE A730 Digital Camera
Olympus TOUGH TG-310 Digital Camera Logo
90 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
