Question about ASUS Eee PC 1005HAG Notebook
Upper plastic cover got cracked, would like to buy a replacement
    Scholar:
  • 156 Answers
Give a try in e-bay usa or uk.
Posted on Dec 01, 2012
Nail gun shoots 1st nail fine then second is a blank. The gun is clean, there is no jam, they are the right nails. PSI is at 100. Person using gun has used this gun and others for a very long time. ...
Miss fire usually occurs when piston/driver is bent, piston oring worn, lower bumper cracked or missing pieces or upper bumper is cracked. Easy to check. Remove head and pull piston. If bent try to adjust, but be careful, blade breaks easily. Piston should fit snugly in cylinder, if loose, replace piston oring. If oring/plastic ring ok examine lower bumper for cracks and replace as needed. If lower bumper ok, pull out headvalve and examine upper bumper for cracks. If upper bumper ok, pull cylinder and look for loose check band around cylinder. Check band is black rubber and should be placed around cylinder fitting snuggly covering series of holes. Replace parts as needed and lube with silicone paste sold at Lowes in the plumbing department (or white grease). Good luck
Jan 11, 2011 | Porter Cable FactoryReconditioned DA250BR...
I have a 98 lincoln town car executive and I need to know how you change the thermostat
1. drain coolant
2. remove engine cover
3. remove the 2 bolts from water hose connection (upper rad hose connecting to)
4. remove o-ring and thermostat
5. repeat in reverse order
Feb 05, 2010 | 1998 Lincoln Continental
Cracked screen cover on Kodak camera
screen protectors are only plastic covers that protects the screen from scratches and such.
It is not possible to buy a new LCD screen.
Since the camera is now Out of Warranty a repair will cost 48 pounds with KODAK.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 13, 2010 | Kodak EasyShare M1033 Digital Camera
2 upper rack rollers cracked in Maytag #MDB7600AWS - cant find simple replacement rollers for inside track - 1 1/4" - of upper rack.
JP Weld works great on repairing these junky Maytag parts. Note that they don't have a replacement for these upper wheels and a guy is selling expensive stainless steel replacements. The round connector broke off of ours that holds the wheel to the rack. My wife found a plastic button that fit within the space and we glued it with JP Weld epoxy (water and temperature resistant). 10 washes later, still working great! I expect it will "heal" any other plastic parts. NEVER will I buy a Maytag again!
Sep 11, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Paying for part for LCD 4010 NEC MONITOR (MODEL: L404G6)
If you can't find the part, glue the crack with ABS pipe cement or liquid plastic model glue (use a toothpick to apply it to the crack from the inside of the part). If the crack is still displeasing to look at, hire a starving artist to make an inlay or custom trim piece to cover it up.
Apr 25, 2009 | Televison & Video
1998 K2500 ignition switch removal
Don't remove the lock cylinder! just break out the small plastic insert inside the upper panel where it slides over the lock cylinder and once its together you will be happy with the ease of installation and the ignition where the key goes in covers up the whole where that little bit of plastic once was
Mar 08, 2009 | 1998 Chevrolet K1500
Hinges
You will have to buy the hinges, and take apart the laptop. Hinges are usually metal, most likly just the plastic covering the hinges are cracked.
Aug 14, 2008 | Gateway 7330GZ Notebook
Casing crack
change the mobile panel and put cover to the mobile! if display have cracks mean buy display stickers and paste it to the display! just try it
May 07, 2008 | Palm Treo 650 Handheld
Garmin GPSmap 76Cx cracked screen
buy a broken one on ebay for parts and replace the outer cover. the same happened to me w/ a similar unit. good luck.
Nov 06, 2007 | GPS
ASUS Eee PC 1005HAG Notebook Logo
42 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
