Question about Kenmore Laundry Center with Electric Dryer
Our kenmore Laundry center model 970-c97912...serial XE01705540 filled up with water and now is totally unresponsive. The dryer still works, but the washer does nothing
I've pulled of the front and don't see any visible problems. Not sure how to test the lid switch. Any help or a service manual would be great! Thanks Jen & Tara
jsrock516
  • 5911 Answers
SOURCE: agitated with my agitator and spin cycle
Your problem could be with your transmission, which is located directly above the drive belt pulley under the wash tub. If they go bad, your motor will still function normally, but the wash tub will not spin or agitate. Now, another possible problem could be a nail or screw stuck in one of the wash basket holes pressing against the outer tub. I have personally seen this a couple of times. A dry wall screw or nail will stop the wash tub from spinning and cause the drive belt to smoke as the motor pulley turns, but the belt stays stationary. That could be the source of your smell. If you're a do-it-yourselfer or do a lot of carpentry work, you may have washed some clothes with a nail or screw in them. Inspect all the holes in the wash basket throughly. A nail or screw can easily be missed if your not looking for it. I hope this may help you.
Posted on May 04, 2007
  • 249 Answers
SOURCE: Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
Posted on Dec 11, 2007
jumptrout51
  • 3361 Answers
SOURCE: Kenmore washer (model # 110 24872300) won't agitate.
Your machine has no belt. It has a direct drive coupling. The direct drive coupling between the motor and transmission must be replaced.
Posted on May 20, 2009
  • 1937 Answers
SOURCE: Kenmore 70 Series Washing Machine Just Hums (Won't Agitate)
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22712100
Also see the Whirlpool / Kenmore service manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are a worn/broken motor coupler.
See the following for how to get to it and check it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=6019c5e82bfa177df953f5d6ebeac983
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
It's possible that the prongs have broken and the humming that you hear is the pieces rubbing against the center rubber piece.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Jan 10, 2010
Testimonial: "Awesome - Thanks!"
blueextc3221
  • 15935 Answers
SOURCE: Kenmore series 80 washer filled with water now unresponsive
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
When I put a light load into washer, follow directions, the washer starts by running water but does not go into next cycle
I would check the lid switch. If switch is faulty, it will allow unit to fill like normal, but won't agitate or spin.
Nov 15, 2015 | Kenmore 24 in. Gas Laundry Center with...
How do I stop my kenmore dryer, model 970-c87172, from beeping? Drying, cool down, wrinkle rid and clean lint filter lights flash 3 times. Start light doesn't flash at all. It does this even
Hi Brenda
First off It seems that you model is not correct. Kenmore model numbers start with 3 number followed by a . and then some more numbers. Most Kenmore laundry numbers start with 110.xxxxxxxx. The number you have looks like a serial number which is no help.
Oct 19, 2014 | Kenmore Dryers
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
Aug 21, 2014 | Frigidaire FFLE2022MW Electric...
My frigidare laundry center, FFLE2022MW will not fill with water at all.
I have a Frigidaire Landry center model # FEX831FS4 I washed a small but heavey rug in it and it quit during the spin cycle and now wont do nothing but the dryer still works...can you help me out?
Aug 21, 2014 | Frigidaire FFLE2022MW Electric Laundry...
I need to replace a broken knob for a kenmore 24" stacked washer/dryer Model 11108875279
Their are a total of 5 knobs on the control panel for that laundry center i do not know which knob one you need so this link is for the parts breakdown of the control panel http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-dryer-combo-Parts/Model-11088752792/0582/0152000/P0403242/00001?blt=06&prst=&shdMod=
Gene
Aug 11, 2011 | Washing Machines
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
Leaks at bottom lefthand corner when filling
On that model it's easy to unscrew the front and take it off. You can then see the hoses etc to see where the water is coming from. I had to replace the drain hose on mine.
Aug 12, 2009 | Kenmore 98702 Stacked Washer/Dryer
Refridgerator not cold
Called Sears to send a technician. Replaced the thermostat (DTS). Fridge is now working. The themostat was $21 + service/labor total $160 +/-.
Nov 30, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Laundry Center with Electric Dryer Logo
180 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
