My acer laptop screen won't turn on. The entire
    Scholar:
  • 156 Answers
It sounds like either your Lcd data cable loose or graphic card fried from excess heat. If you feel excess heat at the bottom of your laptop near the fan ventillation, then most probably it is graphic card. A chiplevel technician can repair your laptop. Don't try any repair if you are not a technician. Any repair without proper knowhow will kill your notebook for ever. Hope i helped you
Posted on Dec 01, 2012
2 Suggested Answers
SOURCE: I have a acer travelmate 5740. When I turn it on
hello sir!
it seems that *********** borad or power board isn't working. just take it to some machenic he will repair it in about 20$ or less..
thank you.
Posted on Apr 18, 2012
Toshiba L455d s5976 laptop will not bootup black screen
Sounds like the GPU has failed to initialize. Common cause is overheating.
Feb 09, 2018 | Toshiba Satellite Cars & Trucks
I have a acer travelmate 5740. When I turn it on the fan whirs for 5 secs then stops. The computer doesn't start and the screen remains black. I've tried holding the power on button for 60 secs as...
hello sir!
thank you.
Apr 18, 2012 | Acer Computers & Internet
Hi, I've disassembled my laptop and I have 2 screws remaining and I can't figure out where they go. I tried turning the laptop on and it won't turn on. Will the missing screws affect this?
The missing screws should have no affect on whether or not it turns on. Try to ensure that all the ribbon cables are properly secured in the correct locations.
Aug 27, 2011 | Acer Aspire 5315 Notebook
Hi there, Mine is a wifi problem.. at home or at a couple of other places I've tried, my Aspire One connects no probs. At work, it constantly tries 'Acquiring Network Address', and on going...
Plug LAN cables or turn ON Wifi.
Enter Run command or type cmd.
on the command prompt screen ( black it is ) type:
ipconfig /release
enter
next type:
ipconfig /renew
enter
type exit
NOTE: if the problems still remains,which means the router use a STATIC ip eg.192.168.1.5
( CONFIG INTERNET PROTOCOL TCP/IP = ip address : 192.168.1.5 subnet mask :255.255.255.0 default gateway : 192.168.0.8 )
akee_akee@live.com
Aug 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
My laptop was left with the top down and turned on. It was plugged in and when I opened it to use it again, the screen remained black. I tried using different keys but nothing would happen. I unplugged...
Hi, Nan.
Disconnect the power adapter, flip the laptop, unlock and remove the battery. Then, reinsert and lock the battery, connect the power adapter and try again.
Hope this helps.
Jul 30, 2011 | Toshiba Computers & Internet
Hi I have a Acer aspire 9410 (9414wlsmi) 17 screen. The problem is that i have no backlight at all, i've bought a new screen + new inverter/backlight driver + new cable but it did'nt help i have...
The inverter/backlight combination isn't the whole picture. The inverter powers the backlight, but the inverter is controlled by a signal commonly called "Brite-On", which comes from the motherboard. If the "Bright -On" signal from the motherboard is missing,then the inverter (and thus the backlight) won't work. The problem you are having is on the motherboard. here's a link to a datasheet of such a device:
http://pdf1.alldatasheet.com/datasheet-pdf/view/245132/FAIRCHILD/FAN7317.html
May 15, 2011 | Acer Aspire 3690 (LX.AFL0J.044) PC...
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Toshiba Satellite A135-S2376, black screen problem
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
Apr 05, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
David Payne
David Payne
