Question about Baby Trend BabyTrend Reebok Jogger
How do I get my cycloputer to work?
I cannot get the cycloputer to register anything. I did get the clock to work, but I cannot get the odometer, speed, stopwatch....anything to register. I have read the directions many times, Can anyone suggest a dealer or place I can go have a person explain how to use this? It has never worked, it was purchased in Sept. of 2006 and I am so disappointed I cannot figure this out.
My odometer does not register. the trip odometer works fine but of course goes back to---- when ignition is turned off off
Hi, David for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Bmw f650gs repair manual pdf
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
User manual f650gs
F650GS ABS light and speedo problem Horizons Unlimited The HUBB
Thread Speedometer tach clock odometer not working
May 12, 2014 | 2004 BMW F 650 GS
Odometer not working on 1997 suburban
Hello BDG, The answer is no. If the VSS fails on your 97 Chevy, you will lose both speedometer and odometer functions. If your speedo is still working and your odometer is not, you have a broke odometer. This is a common failure with a lot of the older vehicles that were fitted with the mechanical odometer registers. Feel free to contact Kincer's Service for a repair salution.
GM Instrument Cluster Speedometer Repair Service
Mar 26, 2014 | 1997 Chevrolet K1500
01 jetta 1.8t odometer and clock stoped working any ideas
abs light on ? abs controls the speedo (odometer).... dont know what you mean by clocks.... do you mean the rev counter and gauges ??
Jan 21, 2014 | Volkswagen Jetta Cars & Trucks
My 2006 heritage odometer will keep total miles. It counts miles driven but once it is turned off and then back on, the milage total always goes back to 2882 total miles
If the speedometer is working and the odomter (mile counter) is not then clock is faulty. Replace as repair is not possible. If the speedo is not registering speed then the gearbox sensor is probably the cause.
Dec 30, 2013 | 2006 Harley Davidson FLSTCI Heritage...
Clock/ odometer both stopped working on my 2005 vw jetta
The line connected to your transmission could be damaged or disconnected... it is how your odometer reads your distance/MPH, etc...
Sep 05, 2012 | 2005 Volkswagen Jetta 4
1988 Chevy pickup odometer doesn't work
they are spring loaded and mechanical. if a spring wears out or breaks it won't work. you can replace it with another one but the actual miles won't be there or you could go with a digital set.
Jul 13, 2012 | 1988 Chevrolet K1500
Odometer is not working
May 11, 2009 | 1996 Ford Explorer
1997 Mercedes C230 clock light and odometer light not working.
You will need to pull out the instrument cluster and replace the bad bulb.
Feb 14, 2009 | 1997 Mercedes-Benz C-Class
Instrument lights for odometer and clock don't work.
if the dash light are not working have you checked the dash display bulbs as what you discribe sounds to me as blowen bulbs
Jan 03, 2009 | 2000 Honda Odyssey
Baby Trend BabyTrend Reebok Jogger Logo
61 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
