Question about Dell Inspiron 1764 Ci3 227Ghz 4GB 320GB 173 Win7Purple Stripe PC Notebook
Dell Inspiron 1764 won't start - Dell Inspiron 1764 Ci3 227Ghz 4GB 320GB 173 Win7Purple Stripe PC Notebook
samaddar07
  • 639 Answers
SOURCE: My Dell Inspiron m5030 won't turn on. It was
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
Just try this and leave a feedback for next steps.
Posted on Jun 16, 2011
  • 36 Answers
SOURCE: my dell inspiron 1545 won't
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Posted on Jun 20, 2011
NomadTrucker
  • 166 Answers
SOURCE: dell inspiron 1501 won't boot
Caps lock flashing indicates faulty memory - it's a POST (Power On Self Test) before BIOS executes. When memory is removed it should indicate "no memory". Carefully re-insert the RAM memory module, check the tiny contacts inside the connector on dust. Then try again.
If there are 2 memory banks (1 one the back, the other under keyboard) remove one RAM memory module.
If capslock keeps on flashing test it with another RAM module.
Posted on Jun 30, 2011
  • 998 Answers
SOURCE: my dell inspiron 6400 won't
The following troubleshooting guidelines are basic troubleshooting steps. Battery Charging It is recommended to charge the battery while the system is off for faster charge times. Users may notice longer charge times when the system is powered on and running graphics extensive applications.
No POST If the system does not perform a Power On Self Test, there are various things to look for:
  1. Check to ensure that the system has a power light.
  2. If the system has no power light, ensure that it is plugged into AC power. Remove the battery.
  3. If the system has power but is not performing a POST, check to see if the keyboard status lights flash to indicate a successful POST, but no video, or that the keyboard status lights are lit in a sequence indicating a system problem.
  1. With the power off and the system unplugged, remove all CRUs from the system and reconnect that AC adapter to the system and try again.
  2. Run the On Board Diagnostics (OBD).
Video If the LCD on the system shows no display, or has other LCD problems, there are some basic steps to take:
  1. If the LCD is not displaying video or the video is garbled, run the BIST Test.
  2. If the LCD is not displaying any video, connect an external monitor to eliminate a no POST problem. A good image on the external monitor eliminates a video card problem or a POST problem.
  3. Connect an external monitor when possible for all LCD related problems, to help eliminate a software possibility or video card problem.
  4. If the LCD has extremely dim video, attempt to adjust the brightness or connect an AC adapter to eliminate a power management conservation setting set in the BIOS.
  5. If the LCD has lines on the screen, check the system during POST as well as system setup to verify if the lines are present in all modes of operation. Run the BIST Utility.
  6. If the LCD has color problems, run the BIST Utility.
  7. Run the On Board Diagnostics (OBD).
Posted on Jul 19, 2011
  • 998 Answers
SOURCE: I have dell inspiron 1764.
Press key and the power button to initiate diagnostic testing on your laptop. You want to see if there are any hardware errors, specifically the hard drive. If all tests pass then your operating system software is corrupted and needs to be re-installed.
Posted on Sep 01, 2011
Master reset code for Inspiron 1764
This is a laptop computer, not a phone or a tablet. There is no master reset code. You reformat the computer using either the discs that came with it, or you use the software provided on a hidden, or visible partition on the hard drive. It is not for the faint of heart, or anyone inexperienced.
Support for Inspiron 1764 ' Dell US
www.dell.com/support/home/us/en/04/product-support/.../inspiron-1764/manualsManuals & documentation for your Inspiron 1764. Last Revised: ... Inspiron 1764 Service Manual PDF (1485 KB) ... Inspiron 1764 Setup Guide PDF (2312 KB).
More information. Look at the Video tab as well.
Inspiron 1764 Google Search
Apr 11, 2017 | Computers & Internet
My dell inspirion 1764 beeps 6 times pauses then 5 more wont do anything else
per the manual 6 beeps is indicative of a video chip failure, 5 is the real time clock, check your warranty date, if it's still under warranty i'd snd it in for repair as the video chip isn't easily replacable
Dec 14, 2013 | Dell Inspiron 1764 Laptop
I can not eject my cd from my dell laptop?
Open Start Menu, Computer, Right click on the DVD rom, scroll down , click on eject.
Dec 29, 2012 | Dell Inspiron 1764 Laptop
Dell Inspiron 1764 Restore to factory defaults settings
Boot up with the Operating System CD, this will install a fresh copy of Windows on your Dell. Then install the laptop's device drivers with the Drivers and Utilities CD.
Sep 04, 2012 | Dell Inspiron 1764 Ci3 227Ghz 4GB 320GB...
I changed my username now my password won't work this is on another computer.It ia a dell windows 7.It don't have a place for a disk
Go to the link below and download Ophcrack and burn the iso to a bootable USB Pen Drive... Boot from the bootable USB Pen Drive and let it do it's magic. You'll have the password shorthly:
http://ophcrack.sourceforge.net/download.php
Jun 30, 2012 | Dell Inspiron 1764 Laptop
Inspiron 1764, dropped it, broke screen replaced screen 1600 x 900 which is supposed to be correct screen , but I the max resolution my computer will display is 1024 x 768
You didn't buy the correct screen if your old screen display different resolutions. There are so many screens that will work for a particular model, but when it comes to resolutions, there's the difference. Look on the back of your old screen and try to match it up with one that has the same model/part number.
Apr 05, 2012 | Dell Computers & Internet
I have dell inspiron 1764. Froze. Restarted, after loading from blue Dell Inspiron bar came up with screen saying operating system not found
Sep 01, 2011 | Dell Inspiron 1764 Laptop - Windows® 7...
Am looking for an owners manual for dell inspiron 1764
You can visit the below mentioned link.........
http://www.freeebookpdfmanual.com/tag/dell-inspiron-1764-manual/
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Computers & Internet
Dell Inspiron 1764 Ci3 227Ghz 4GB 320GB 173 Win7Purple Stripe PC Notebook Logo
261 people viewed this question
Alun Cox
