Question about Dremel 6000 Contour Sander
Has dremel 6000 contour sander been discontinued i need sandpaper and sanding tubes but cant find any
Www.supergrit.com has the sanding tubes for the Dremel 6000 in stock
Posted on Apr 11, 2013
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: I need spares for my Dremel 6000 sander
Most likely you will find them on EBAY---search there for Dremel.
Posted on Nov 04, 2012
74-674 sandpaper black & decker sandpaper
Have you tried the hardware store where the sanders are sold?
Jan 01, 2016 | Sander Tools & Hardware - Others
Why has my dremel 6000 just stopped working could it be the brushes
Although Supergrit Abrasives in Gettysburg, PA sells the sleeves and the Hook & Loop diamonds for use with the Dremel 6000, we do not repair tools. The 6000 is discontinued, but you can probably buy a used one that works on Ebay.
Jun 14, 2014 | Dremel 6000 Contour Sander
Festool RO 125 leaves scuff marks when sanding
depends how important it is to vacuum the dust, most generic brand sandpaper discs will have different hole placements for the sander and the vacuum cant suck the dust up. if you are getting swirl marks from the edge of the sander, is the disc too small? a generic brand that is slightly larger may work but try and keep the sander flat or the excess disk can cause a little trouble with the finish.
Apr 27, 2014 | Festool 492271 5 Inch Stickfix Interface...
Nov 04, 2012 | Dremel 6000 Contour Sander
Sandpaper keeps coming off while sanding. Why and how can I remedy situation. I was thinking about replacing rubber cover on clamp.
I switched it to a new pad and the sandpaper is still flying off :( I just don't get it the paper is not even half used up. my sander is the hook and loop velcro one ugh its driving me nuts I have to keep buying more sandpaper when the sandpaper is not even worn out! BTW Mines a dewalt hook and loop random orbit sander
Jan 03, 2011 | Bosch 1297DK 14 Sheet Palm Sander Kit
Sheets keep coming off during sanding
The sandpaper will come off for one of these reasons: 1. The spring clips are to loose to hold the sandpaper. 2. You are using sandpaper that the paper's either too thick for the clips to hold it or too thin to withstand the work you are putting it through. 3. (Most likely) You are pushing down on the sander too hard while sanding. These types of sanders work by their own weight with only a little help from you.
Dec 30, 2010 | Bosch 1297DK 14 Sheet Palm Sander Kit
I lost the manual for my sander
If you provide the model # for the Dremel sander I'll be happy to search for you
Dec 20, 2010 | Dremel Tools & Hardware - Others
Change sandpaper head on dremel motor tool
if your talking about the barrel sander there is a screw on top that you loosen and the barrel will slide off put the new one on tighten screw and your good to go
Jan 09, 2010 | Hand Tools
After replacing the brushes in my old Rockwell belt sander there is excessive arcing between the brushes and the oommutator and the unit doesn't come up to full speed.
Did you dress the brushes to the contour of the commutator?
You wrap the commutator with fine sandpaper and rotate under the brushes till the curve conforms.
If this does not reduce the arcing, then you may have an armature with a bad winding.
Sep 30, 2009 | Bosch Tools & Hardware - Others
Need to attach sandpaper and holder
take your sander to any hardware store and ask the clerk to show you the kinds of sandpaper and holders available. there are several adhesive backed peel and stick varieties and others that are loop and hook, like velcro. happy sanding.
Aug 22, 2009 | Tools & Hardware - Others
Dremel 6000 Contour Sander Logo
2,675 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
