Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Need to install water supply hose - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
  • Hoover Master
  • 18,424 Answers
Here is the manual > http://hoover.com/file/604/
here is video instructions >
View the Video Instruction Guide
Posted on Dec 02, 2012
Dirt devil ce6100
Hi there! Below are step-by-step instruction to assembling the hose to the cleaner so that you may use the attachments. I have also included a link to the instruction manual which gives instructions and illustrations as well. Hope this helps!
1. Put cleaner in its upright position. Connect the upholstery attachment to the trigger adaptor.
2. Remove the dirty water tank door.
3. Insert the hose adaptor into the dirty water tank.
4. Connect the base water supply connector into the fitting on the lower left side of handle facing cleaner. You are now ready to do above floor cleaning!
http://pim.ttifc.net/document/1549/
Jun 13, 2014 | Dirt Devil CE6100 Featherlite Upright...
Been cleaning for 2 hours now with my Bissell Quicksteamer and on my next run i presses the water release trigger on the handle and water isnt being squirted on the carpet..why?
ran out of water? (if water) >
Is there some form of water filter?
Problem with the trigger?
Bad steam heating element or the power connection supplying the power to it?
Of could it just be tired and need a break? (grin)
Best Regards
Ck
Aug 16, 2011 | Vacuums
My Simoniz S1900 pressure washer "pulses" on and off when I turn it on and pull the trigger. I have purged the pump of air as pre the company's video but nothing helps.
One thing to check is that the hose connected to it isn't collapsing and cutting off the water supply. Make sure plenty of water pressure and volume at hose as well.
May 23, 2011 | Vacuums
How to install hose to cleaner
Take the top lid off the dirt tank. Pull the white plastic block from the front of the dirt tank out. Then put you hose into that place of the front dirt tank and plug in you small water hose into the top of the hood that says water dispense. Put the lid back on. That's it.
Dec 01, 2009 | Hoover F5906-900 Upright Steam Vacuum
Iam trying to use the upolhstery piece. Iam squeezing the button and no cleaner is coming out. Iam using by hoover steam vac deluxe spin.
Confirm that the hose is correctly connected to the clean water supply. If so, then remove it and, with the trigger operated on the hose, try to blow into the water feed connector. If you cannot pass air, the feed tube in the hose is clogged and must be cleaned (either by running faucet water into the brush end (with trigger pulled) or by using compressed air....
Nov 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover steamvac ultra. The handheld hose
If you have installed the hose properly, try to hold your hand over the suction end with the cleaner on to prime the water in the hose. There is no way to dissasemble the hose. You could have a possibility of a few thing that have failed,
1. the pump that feed the hose
2. the valve on the hose end
3. the check valve where you connect te hose to the machine
Also verify that you are dispensing solution to the floor, if so, then the above needs to be checked.
Have it looked at at repair shop for diagnosis
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 09, 2009 | Vacuums
How do I get the handtool to work on my Hoover Steamvac carpet cleaner?
Please reference page 11-12 on this manual:
http://www.hoover.com/pdfs/manuals/F6039900.pdf
The tools are plugged on to the end of the hose, and the hose supplies water and vacuum to the tool.
Oct 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water leaks out under the unit when using the upholstery attachment?
You may wish to check and see if the leak is where the small water supply hose is plugged in to the cleaner base. That connecction supplies water from the product, to the spray end on the upholstery hose.
Sep 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover f5520 steamvac duo upright wet washer
Your problem is inside the vacuum hose where they have installed a small coiled hose that carries water to the smaller power head for upholstery. After taking this apart I found the inner smaller coiled hose was broken at 2 different places. A very poor design and poor quality material. The hose looked like it was rotted. This could be from old detergent left in the line or maybe the wrong detergent. A job to get it apart but if you remove the three screws that hold the side plate over the electrical you can block that hose off and the machine will work on floors only as the water to the power head is terminated.
Nov 11, 2007 | Hoover F5520 SteamVac Duo Upright Wet...
Water flow issue
The attachment hose is likely coaxial - meaning that it is a vacuum hose with the water supply line running through it. It is likely that the vacuum (outer) hosing is damaged. The attachment will still spray, but will not vacuum. if you lay the handle section all the way down and look inside the unit, you will probably find the problem.
Aug 23, 2007 | Hoover F7431-900 SteamVac Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
