Question about Kicker Used Kx600.4 Amplifier 4 Channel Amp With Crossover Loud And Clear
My kicker kx600.4 amp remain on protection mode
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
There is a internal problem with it ,That is causeing it to overheat,
Posted on Dec 03, 2012
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Check ohm reading of the speaker. Should read close to whatever the spec is (2 ohm, 4 ohm, 8 ohm) if you have multiple subs and no ohm meter then try connecting one at a time to the amp. Either you have a shorted sub, ohms are too low for the amp or you have an (least likely) amp problem tha y only shows up under a load.
Aug 01, 2016 | Kicker Car Audio & Video
Kicker kx850.4 protection light stays on know power light
Check power make sure you have solid 12 volts. Disconnect speakers, shorted speaker can cause protection mode to engage. If still in protect mode will need to repair. Kicker does out of warranty repairs on kx series amps or try T.I.P.S contact at linearpower.com. Iirc Ray @ tips was one of the engineers at kicker back when kx series was introduced.
Jul 19, 2016 | Kicker Car Audio & Video
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
My kicker solo baric is moving to the bass but is not putting out any sound. I've swapped the subs to see if it was the sub but it wasn't. I believe it is the amp but im not sure. The amp is in protection...
YOU HAVE A SHORT CIRCUIT WITH THE RCA CABLES THAT ARE GOING THO THE SUB WOOFER AMP CHANGE THE RCA CABLES FOR A NEW ONES!! AND IF YOU CAN BUT IT HEAVY DUTY
Feb 10, 2010 | Kicker Car Audio & Video
Kicker zx750.1 Amp in Protection Mode (Red LED)
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker amp
if you amp is in the PROTECTION MODE its means that there some defective part , like for example the main ICs or TRANSISTORS output might be defective , and thats why its on the PROTECTION MODE , needs to be taken to a expert technician for repair.
Apr 16, 2008 | Kicker DX350 Car Audio Amplifier
My amp goes into protection mode at high volume
need more info, make and model of amp and subs please
Feb 18, 2008 | Kicker DX350 Car Audio Amplifier
Kicker Used Kx600.4 Amplifier 4 Channel Amp With Crossover Loud And Clear Logo
47 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
