Question about Ericsson W35 Unlocked Gsm Mobile Broadband Router 3g Fixed Terminal Fax Voice
I want to reset my ericsson router 3g password
I need to set the router password
    Sergeant:
  • 316 Answers
If the default password has been changed and you do not know the current password, use the Reset button to reset the W3x to factory default configuration. This will reset the login password to user.
Posted on Dec 05, 2012
  • macovet
    macovet Apr 13, 2014
    Password reset doesn't work. Trying to login through telnet but I need the bell's root password for the device.
What is the login password en tenda router
Defaults for your router are:
Username:Admin
Password: Admin
If you have changed this you may need to hardware reset your router
Jul 18, 2014 | BestPriceCables Tenda 3G622R 300Mbps...
Chromebook won't connect
This will reset the wireless router back to factory setting, and you will have to change the password or know the default password. There is a small button in between the power cable and the usb port. you need to push that in, usually done with a paper clip. admin is the wifi password after a reset. admin is the login username and password to make changes to the router.
Dec 29, 2012 | NexAira Nexconnect 3g Wireless Broadband...
I want to unlock Ericsson W35 router
Unlock? If you want to remove the security, reset the device. Try this user manual: http://www.ericssonw35.com/pdf/W3x_userguide.pdf
Dec 27, 2012 | Ericsson W35 Unlocked Gsm Mobile Broadband...
IPhone won't connect to wifi
Under Settings- General - Network, I turned off "Enable 3G", waited a few seconds and wifi came on. I turned on the "Enable 3G" and it still kept my wifi connection.
Go to router's security which is set to WPA2, and re-set it to WPA2, changed the password, removed the network from my iphone and then reselected it with the new password.
Try rebooting your router, or re- setting the security of the router. Also, see if there is a firmware upgrade available for the router.
Download the latest firmware for your router, you can go to the routers manufacture website or there is usually a link within the routers settings. (if you have the routers software installed on your computer, you can access the settings and software update link)
If all else fails, you can reset the router, this different than simply restarting it. You will need a pin or paperclip to press the reset button usually found on the back or sometimes on the bottom of router.
PLEASE NOTE: Resetting the router will delete all current settings including securtiy and reset them to their factory default settings.
But this will isloate any issues that may be associated with your current settings including security. You can reconfigure your router with the settings you perfer after determining that the issue is with the router or not.
Oct 29, 2012 | Cell Phones
I forgot my aztech password and i would like to retrieve it. How will i do that?please give me details....recovering d said password without resetting it again
If you have manually changed the password on the router from the default (admin/admin) and you don't know what the password was changed to, then the only way to access the router again would be to reset it back to factory defaults.
Feb 28, 2011 | Aztech HW550-3G 300Mbps 802.11n Mimo...
How do i reset my password for wi-fi internet?
If you are talking about the "password" that you need to connect to your wireless network, you have to access the router buy having a computer plugged in it directly through ethernet and change the settings in the router.
Thank you,
Lee
Aug 26, 2010 | Apple iPad 32 GB 3G Tablet PC
Flashing wifi symbol on netgear wireless router. iphone help
Hi
I will try to help you out with this....
Might be you tried to cinnect with the network many time thats why its keep on disconnecting,
you can delecte all the netwoks that you have in you 3G Iphone and try to connect fresh, if its still give you the same error then you need to change the channel on the router if still it wont connect I suggest you to change tehw ireless settings on you router and reconnect all the computer and you Iphone again with the new network...
Steps are below before you change any settings on teh router i would like to inform you that you will loss your wireless connection till you reconfigure and reconnect you computer with the new network again........
open the internet explorer on your wired computer
type in 192.168.1.1or you can type http://routerlogin.com
, it will prompt you for user name and password, the user name will be 'admin' and password will be 'password', make sure you type it in small case
click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I hope above mention will resolve your concern.....
Thanks
Harmeet :)
Sep 27, 2009 | NetGear RangeMax WPN824 Router
Trouble connecting ipod touch to password protected wi-fi
Settings->General->Reset->Reset Network Settings.i did this on my touch 3g & it started working!
Dec 26, 2008 | Audio Players & Recorders
Ericsson W35 Unlocked Gsm Mobile Broadband Router 3g Fixed Terminal Fax Voice Logo
175 people viewed this question
Top Ericsson Computers & Internet Experts
David Payne
David Payne
Are you an Ericsson Computer and Internet Expert? Answer questions, earn points and help others
