Question about Watches
How to use chronography of fossil fS-4542
I don't know how to use chronography
4 Suggested Answers
  • 172 Answers
SOURCE: I haven't worn my fossil
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
Posted on Jun 01, 2011
  • 2501 Answers
SOURCE: hi! I would just like
If you type ES2453 in google you should be able to find advertisements for this watch, even though it is not on their web site.
I suspect that it is a discontinued model, as all the models on their web site have larger numbers.
Posted on Jun 16, 2011
rtomlin961
SOURCE: Fossil watch battery
It is a 364 battery. You can order these online from many battery outlets, even ebay.If your watch is 5ATM or more, it has a pressure seal, and you might want to send it to the Fossil service centre to have it changed and resealed.
Posted on Apr 11, 2012
Where could I find an owners manual for Fossil Arkitekt FS-2934 ?
Try Googling (fossil)(FS-2934)(manual) without parens.
Jul 17, 2017 | Fossil Watches
How do you take the back off the fossil watch fs-4023
I have a Fossil and a Nixon watch that have very similar backs. Usually when it has those grooves all the way around, the back just screws off. I know they make some special tools to twist it, but I had luck with gently using some needle nose plyers.
Hope that helps and good luck.
Feb 13, 2015 | Fossil Watches
How do i set the month on my fs-4250
Google (fossil)(Fs-4250)(manual) without parens for month setting instructions.
Sep 14, 2014 | Fossil Arkitekt watch
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
What battery does the fossil fs 3105 watch take
It's actually a lot easier than that video shows. You're trying to represent a watch that is a PDA! To change the battery in your watch, you need to purchase a watch kit on eBay for about $15-$25, purchase the correct battery, watch a realistic video of changing a battery on Youtube, and then you will never need to pay more than the cost of a battery (a few dollars) to change your watch battery ever again! Sending it to Fossil takes time and money and you can do it at home with basic skills!
Jan 16, 2011 | Fossil FS3105 Wrist Watch
I don't have the original battery to my watch, and am looking for a replacement. The watch is a Fossil Arkitekt FS-3031
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</A></P><P>Best regards.</P>
Aug 24, 2010 | Fossil Watches
I need an extra link and the receiving end clasp for my fossil steel fs 2700 watch. Anyone know where to get?
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care" and then look under "Product Info" on the left and you will see "0rdering links and bands"
Feb 14, 2010 | Fossil Stainless Steel and Leather...
Can't find the watch band for fossil arkitekt fs 4127?? it have a curve and use two pins
I have the same watch Fossil FS-4127 and I too can't find a replacement band. Appears to be planned obsolesence by Fossil. This FixYa site is almost as bad as Fossil, which is all advertisements and no answers whatsoever.
Jan 03, 2010 | Frontgate Watches
Watches Logo
108 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
