Question about Moen 87440 Single Handle Kitchen Faucet with Sprayer Chrome
Moen kitchen faucet 87440 single handle model
Fixed a leak, but handle now operates backwards - away from the front of the sink & only toward the back. Tried taking handle off & putting back on a couple of times, but always with the same results. What is the mechanism that directs the handle? I must have it put together incorrectly in some fashion. Thanks.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Remove stem, turn it half a turn in either direction (180deg.) replace stem and your good to go
Posted on Dec 21, 2012
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
  • 127 Answers
SOURCE: the cartrige inside my moen faucet leaks
moens website. they have parts break down and diagrams
Posted on Dec 05, 2009
motor1258
  • 6674 Answers
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Posted on Dec 29, 2009
ftw1952
  • 10319 Answers
SOURCE: moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
Posted on Feb 14, 2010
  • 67 Answers
SOURCE: Single handle Spray faucet leaks at it's base,
If you still have the receipts from the purchase call Moen directly as they warranty their faucets for life and will send you the replacement parts you need. If you need to purchase replacement parts then you can purchase a Moen single lever repair kit from your local hardware store which should run you around $10. Go the the Moen website and look for your model. They generally have an exploded view of every one of their models that will assist you in dissassembling the tap without any surprises. Reassemble the tap with the new o-rings etc installed and test.
Posted on Aug 11, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    I have taken the holdign retainer out of my moen 87440 but can't get the stem out please help
    the stem is part of a cartrige its either brass or plastic covered with about 6 " O " rings. it gets corroded in place. moen sells a cartrige puller. see a plumbing supply house such sa HUGHES SUPPLY or Ferguson or o local plumber.
    May 20, 2011 | Moen 87440 Single Handle Kitchen Faucet...
    Do not know what seris of Moen facet I have. The house was built in 1984. I have got water lines off underneath but can not get faucet it self off. Took out the screw and the ring screw and base ring screw...
    If it is a single hole faucet, there should be a single nut on the threaded brass piece underneath the sink. You may need a basin wrench to get access to it if you cannot get to it with an adjustable jaw wrench. This nut normally clamps against a U shaped washer that is against the underside of the sink.
    Mar 10, 2011 | Moen 87440 Single Handle Kitchen Faucet...
    How do I repair the sprayer on my Moen kitchen faucet
    new ones are about 10 bucks,unless you just need o ring.they simply unscrew from hose
    Jan 28, 2011 | Moen 87440 Single Handle Kitchen Faucet...
    Single handle Spray faucet leaks at it's base, leaking under the kitchen sink
    Aug 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Moen faucet removal
    Feb 13, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Moen single handle kitchen faucet, Hot water and
    Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Moen 87440 Single Handle Kitchen Faucet with Sprayer Chrome Logo
    332 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
