Question about HP Photosmart D7460 Printer
Touch screen on hp photosmart D7460 printer doesn't work
antiochpc
  • 1314 Answers
SOURCE: Lost installation disk to HP
Go to one of the following:
For Windows XP
For Windows Vista
Posted on Jul 05, 2008
sodeep
  • 3267 Answers
SOURCE: how to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Posted on Mar 22, 2009
  • 30 Answers
SOURCE: On my Photosmart D7460 HP
1) connect printer directly to wall
2) try different walloutlets
3) unplug the power from the back of the printer and then press and hold down the power button for 30 sec release the button. plug in the power chord..
4) if it does not work service the product
Posted on Mar 27, 2011
  • 1196 Answers
SOURCE: HP Photosmart D7460 have a fejl. Oxc18a0306. I
I will suggest you try reset the printer, follow the instruction below to reset your printer, if the problem still persist, reinstall the printers driver, you can also replace the cable that connects the printer to the power outlet. If that did not still fix the problem,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.This should fix the problem.
Posted on May 16, 2011
  • 10406 Answers
SOURCE: I have an HP Photosmart
The new ink-cartridge probably is OK.
So, start the HP Printing Assistant Software, and run the "Print-Head-Cleaning" utility, to run a few cycles. Hopefully, it will unclog the ink-jets that _should_ be spraying ink onto the paper.
Posted on Jul 25, 2011
Can you make copies on model D7460 HP Printer
Unfortunately no, there is no scanner bed so it cannot make copies. This printer is primarily for printing photos and plain paper docs. See Amazon's original review on this product in 2007: http://www.amazon.com/HP-D7460-Photosmart-Printer/dp/B000SNP0RW
NOTE: Our Inkjet411 printer/cartridge support site provides technical tips for for 4000 printer models and includes over 80 videos for do-it-yourself printer remedies and corrections: http://inkjet411.com/
To refill your own inkjet ink cartridges, refer to our Refill Store Map Locator (over 600 retail store locations in North America): http://www.go2ris.com/#retailpartners
Alternatively, if you would rather purchase new inkjet ink cartridges, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Aug 21, 2014 | HP Photosmart D7460 Printer
Ink failure
if your ink isn't working you need to replace the cartridges. Look up your model on the internet to know what type of cartridges you need to buy and how to replace them.hope this helps!
Apr 09, 2012 | HP Photosmart D7460 Printer
On my Photosmart D7460 HP printer, the error code 0005FBB6 keeps coming on the screen saying that I have not powered down properly... not allowing me to print and setting off all sorts of flashing...
Mar 26, 2011 | HP Photosmart D7460 Printer
Need to reset photosmart d7460??
hold power button for 30-60 seconds after turning it on it should reset
Dec 21, 2009 | HP Photosmart D7460 Printer
Error message fatal error during
make sure its compatible with computer before installing because you computer need to recognize the printer after you pluged the printer with computer
Oct 14, 2009 | HP Photosmart D7460 Printer
Photosmart D7460 will not print envelopes from Printshop 23
u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
Jun 14, 2009 | HP Photosmart D7460 Printer
HP D7460 printing blank pages, no error message
Just needed to be unplugged (both at wall and at printer) for two minutes. Restarted and it worked fine.
Nov 22, 2008 | HP Photosmart D7460 Printer
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart D7460 won't print
Did they suggest uninstalling it from device manager, completely and downloading the new vista driver fo your printer off the HP website??? and then installing this.
Feb 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP Photosmart D7460 Printer Logo
190 people viewed this question
Seeker5211
Seeker5211
