Question about Watches
Look can someone help me set the digital time on my watch please its omega seamaster polaris cheers....
    Sergeant:
  • 198 Answers
Your watch uses a calibre 1665 movement. You might contact After Sales Service and ask them if they would send you an owners manual. Setting the time and date is fairly straight forward but you also need to sync the analog and digital displays so it is a bit difficult to describe in just a few words.
The basic guideline is
To select function - turn the crown
To change function - pull out the crown and then turn it
To start and stop functions - press the crown
Posted on Dec 02, 2012
SOURCE: omega seamaster
sounds like an auto wind watch,you must wear this watch most of the day to keep it wound up.to wind the crown must be pushed all the way in.
Posted on May 04, 2007
Cory5468
  • 125 Answers
SOURCE: Omega Seamaster battery
Well maybe if you use a coupon then the price will be lower.
Posted on Mar 06, 2008
SOURCE: omega seamaster professional chronograph
It requires a service.
Posted on May 25, 2009
  • 183 Answers
SOURCE: Why do the Omega Seamaster watches have a second
This is a helium release valve.
The purpose and function of the helium relief valve is a common point of confusion. It has nothing to do with normal underwater diving. Neither does it have anything to do with the depth rating for a diving watch. Helium does NOT seep into the watch while the watch is in water at any depth!
To put it simply, you can completely ignore a helium relief valve. This feature is not used in any way with any form of normal SCUBA diving or anything else that involves less than a multi-million dollar deep sea exploration project.
SCUBA diving activities normally occur at depths of no more than 120 feet. At 250 feet, air becomes toxic due to changes caused by the high pressures at such depths. For those who do very deep sea research, they often use diving bells, dry dive suits, and other types of very deep ocean exploration vessels. In some of these, a highly helium-saturated atmosphere is used to avoid the air toxicity effect.
The purpose of a helium release valve is for people who wear their watch inside the helium-saturated environment for an extended period. Because helium is the smallest atom, it will seep through the watch's seals under the high air (not water) pressures in this environment. If the watch stays in this environment for an extended time, helium will continue to seep in to the watch until the air pressure inside the watch (initially surface air pressure) equalizes to the air pressure in the environment.
This becomes a problem when the vessel is brought back up and depressurized. The helium which seeped into the watch over a couple of days, cannot seep out any faster. The excess pressure inside the watch needs a way to release faster than it seeped in. It is only in this situation that a watch needs a helium relief valve at all. If a relief valve was not on the watch, the excess pressure would likely escape by pushing the crystal out.
But, unless you are in this exact situation, you should never keep this valve open. While the watch is designed to maintain most of its waterproof abilities even when the valve open, it still serves no purpose and increases risk of damage to the watch to do so.
Posted on Sep 23, 2009
Testimonial: "What a totally great reschearched answer!!! Very informative!!!"
  • 93 Answers
SOURCE: omega automatic seamaster losing time
Most likely your watch needs to be serviced.
Every watch, both mechanical and quartz needs regular service.
When the oils in the watch dry out they get gummy and will work against the gear train. They also stop lubricating and friction builds up causing wear.
Hope this helps,
Ken
Yellowstone Watch Inc
Posted on Oct 05, 2009
May i have information about omega watches?
Top omega watches internet wide free delivery. For Omega watches, quality, creativity and innovation work together. It can make use of the better of materials to style its watches. visit it http://sbwatches.com/
Apr 06, 2014 | Watches
Need help setting digital time on my omega seamaster polaris watch please...
Give it up. No matter how hard you try, you will never be able to set digital time on a NON-DIGITAL WATCH.
Dec 01, 2012 | Watches
Set date on omega seamaster quartz 1425
When you pull the crown (winder) , you will notice it has two positions (two clicks). The first click is for quick date setting, the second click is for time setting (moving hands). Second click can be use for date setting as well, but for this you need to move watch hands forward for 24 hours to pass 12 o'clock.
Feb 25, 2011 | Omega Seamaster 300M wristwatch
Omega automatic seamaster losing time
Hope this helps,
Ken
Oct 04, 2009 | Omega Seamaster 2561.80 Wrist Watch
Omega seamaster professional chronograph
That is something that can only fixed by sending it in to Omega for service. You can take it to an authorized dealer or send it in youself. The customer service info in on there website.
Jun 09, 2008 | Omega Seamaster 2561.80 Wrist Watch
Feb 06, 2008 | Omega Seamaster 2541.80 Wrist Watch
Omega seamaster gmt
what you have to do is that pull the crown to halfway do not pull completely out, if you pull halfway out and then move the crown to clockwise or anti clockwise it will change the date. if you pull completely out then it will change the time.
Nov 07, 2007 | Omega Seamaster 2561.80 Wrist Watch
Omega seamaster
Jan 10, 2007 | Omega Seamaster 2232.80 Wrist Watch
Watches Logo
111 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
