Question about Casio FX-300MS Calculator
Unwanted letters DEG show on Casio FX-100A display
The letters DEG have been on my display for about 2 years. I have tried pressing every key combination to no avail. Would love to get rid of them.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
No!! deg mean degree the system of answers you get, you can change it to rad=>radians but you never get rid of them. Sorry :(
Posted on Jul 06, 2009
How do you change it to degree mode
Press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Gradappear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press 1.
Let me know if this helps!
May 02, 2011 | Casio FX-300MS Calculator
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Apr 13, 2011 | Casio FX-300MS Calculator
Ok so my math hw only gave me the degree, minute, sec format of the angle. How do i input it in the fx 155 es to work out and find the rest of the angles, sides, etc?
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
This showed you how to enter angles in DMS or DD. For the rest 'find the angles, etc.' you should refer to your trigonometry manual: You have the definitions of the trigonometric ratios, the sine law, the cosine law to resolve triangles.
Feb 24, 2011 | Casio FX-115ES Scientific Calculator
How do I convert from decimal degrees to degrees, minutes, and seconds?
You have a key, the label of which is the degree sign, the apostrophe and the double quotation mark. It is located between the change sign key (-) and the [HYP] key.
To enter an angle with degrees, minutes and seconds you use the key to separate between numbers
Ex: 18 deg 0' 45" you press 18 [Deg ' "] 0 [Deg ' "]45 [Deg ' "] [=] As you type the calculator displays 18 deg 0 deg 45 deg but the result will show correctly. You have to press the key after the seconds figure, otherwise you get a syntax error.
While the foregoing result is still in answer memory, if you press the [Deg ' "] key the result will be displayed in decimal degrees.
The key is used to enter the DMS values and also to toggle between DMS and D.D.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Degrees seconds and minutes
Sorry, text was posted as clarification request. Here it is
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
Time problems
Sorry to say it but the DMS key is to convert between Degrees, minutes, seconds and decimal degrees (angle units). This cleared here is how to use the DMS key on this calculator.
Jan 14, 2010 | Casio FX-115ES Scientific Calculator
Casio fx-300es---how to convert radians to degrees
You use the key combination [SHIFT][ANS] (DRG>).
If the default angle unit is degree
Type in the angle value in radian, say 1.2.
Press [SHIFT][ANS] (DRG>).
The screen displays 1: deg symbol, 2: a raised r for radian, and 3; a raised g (for grad).
1.2 [SHIFT][ANS] (DRG>) [2: raised r] .
The screen displays 1.2 with a raised r to the right of the 2.
Press [=].
The answer is 68.75493542
Dec 02, 2009 | Casio fx-300ES Calculator
How to use the cosine,tangent etc functions of calculator fx-82ES plus
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
Nov 05, 2009 | Casio Office Equipment & Supplies
How do you put casio fx-300MS in degrees mode? please help
To change the default angle unit, you press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Grad appear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press the number key corresponding to your case, 1. All angle values you feed the trigonometric functions will be considered to be in degrees. If you use the inverse trigonometric functions to find angles, the results will be in degrees.
Hope it helps.
Thank you for using FixYa and do not forget to rate this free solution.
Nov 04, 2009 | Casio FX-300MS Calculator
Can't find angle measurements function on casio fx 9750
In [RUN], screen press [OPTN][F6:->][F5:ANGL] [EXE].
Exemple 18.53 deg
18.58 [F1 Degree symbol] [EXE] shows 18.58. At the bottom of the screen appears a new option DMS with a left arrow. By pressing the corresponding key [F5], the screen displays 18 deg 34 min and 48 secs. To enter an angle in DMS, exemple the one above, you procedd as follows:
18[F4]34[F4] 48 [F4] [EXE] displays 18.58
Hope it helps.
Aug 20, 2009 | Casio FX-9750GPlus Calculator
Casio FX-300MS Calculator Logo
274 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
