Question about Sceptre X240BV-FHD LCD TV
What is the best dvd player for a sceptre 32 lcd hdtv
Having an issue trying to connect a magnavox dvd player. Have HDMI 1-3 on my tv and wondered if that would be better.
  • 1 more comment
  • Carol Wherrett
    Carol Wherrett Dec 02, 2012
    wouldn't i just need an hdmi cable?
  • Carol Wherrett
    Thinking about returning my magnavox dvd player for an hdmi dvd player.
  • Loretta Northcutt
    Loretta Northcutt Dec 02, 2012
    Yes that's all you need. Then you will have to remember to switch inputs/sources on your television. Blu-ray players are inexpensive enough these days to justify purchasing them.
  • Sceptre Master
  • 736 Answers
Yes, an hdmi connection is the very best. However, if you are not able to connect your dvd player the other way, just choosing hdmi or not might not solve your issue. Hdmi connections allow upconverting and thus a higher picture quality for you.
Posted on Dec 01, 2012
5 Suggested Answers
SOURCE: new Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
Posted on Mar 29, 2007
  • 6 Answers
SOURCE: Sceptre X37sv-Naga 37 HDMI port is not making contact
hd EZ lock by Blue Echo Solutions is a Universal HDMI Locking Adapter, the only one on the market. It works with most HDMI Cables and components and attaches to your component's chassis, using the existing screw above or below your HDMI Input or with the supplied adhesive. It supports your HDMI Cable from the component's chassis, eliminating stress on your HDMI Input and keeping your HDMI Cable in place. www.blueechosolutions.com
Posted on Jun 28, 2009
SOURCE: Sceptre 32 tv won't turn off or change channels,
I have the same problem, did you ever get this fixed?
Posted on Feb 17, 2010
  • 9 Answers
SOURCE: I have an Sceptre 37"
For most TVs in the market, you would use their DYNAMIC or VIVID mode for the best picture settings.
Posted on Sep 09, 2011
When you chose the settings menu what do you chose to set the tv to hdmi to get the dvd/blue ray player to play
There are two HDMI inputs on your TV, so, depending on which input the DVD player is plugged into, HDMI 1 or 2 , that's the one you choose. The menu should list the inputs as HDMI 1 and HDMI 2.
May 19, 2014 | Emerson LC320EM9 32 in. LCD HDTV
White flashing on netflix with hdmi cord
This happens with all three? You have a bad HDMI circuit in your TV. The Main pcb, will need to be replaced.
Apr 19, 2012 | Sceptre X320PVFHD 32 in LCD TV
Sceptre HDTV HDMI ports won't work?
Make sure you are on right input. On your remote press input until you are on the right one.
Apr 26, 2017 | Sceptre Televison & Video
I PURCHASED A MAGNAVOX Z V 427MG9 A VHS DVD RECORDER.I HAVE A NEW VIZIO VW26L HDTV. HOW DO I CONNECT THEM? I HAVE ALREADY CONNECTED A HDMI CABLE TO IT BUT DON'T KNOW TO SET IT UP. DO I NEED ANY OTHER...
HDMI cables are actually wonderfully simple to connect. Once you have connected one end to the TV and one end to the DVD player, you will simply need to change your input channel using your TV's remote. Find a Input or Video source button and press it until the screen says HDMI. Now your TV may have several HDMI ports so you may have to try a couple HDMI channels before you find the right one.
Hope that helps!
Jul 19, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
What cables do you need to connect a dvd player to a vizio hdtv
If your dvd player has a hdmi hook up "easy" just use 1 hdmi cable from the dvd player to the tv. If not use the 5 cord for better picture quality.
Nov 08, 2009 | Vizio L32 32 in. LCD HDTV
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Open Questions:
Text looks awful on monitor - not a ClearType or videocard problem Hey guys, Background: I recently built a new rig and I'm using a new video card - Nvidia 480. On the video card end it's connected with mini-HDMI and on the monitor it's connected with HDMI. My monitor doesn't have DVI and my previous computer didn't have HDMI. The monitor is a Sceptre X240BV-FHD and has a ATSC tuner. I think that's the culprit. The problem: The text looks overly sharp and pixelated. It's hard to read. BUT if I play a video game it works fine. The screen is too far zoomed in when set to 1080, which is what the monitor natively supports. I fixed that with the Nvidia control panel, though. What I've tried: I'm currently using the latest driver: 296.10 I've tried adjusting the cleartype settings. The cable is OK because. I just bought it from monoprice.com. I've also used DVI-HDMI and that didn't work. I've tried adjusting all of the monitor settings I can... nothing has fixed it yet. There is a generic driver for the monitor, but that's what it was on the old rig also. If I take a screenshot to post on here, everything looks correct. So, I think the video card is sending the correct information and the monitor is goofing. But I understand it can be caused by EDID flags the monitor is setting. I've hooked up my video card to other computers and it looks fine. I've hooked up another computer to my monitor and it also looked screwed up. Notes: Oddly, I've used DVI-VGA and that fixes the problem... but then that introduces problems with HDCP while trying to play Blu-Ray movies . Does anybody have any ideas? Thanks, Joe
Feb 28, 2017 | Sceptre X240BV-FHD LCD TV
Sceptre X240BV-FHD LCD TV Logo
200 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
