Question about HP Photosmart Premium C309A All-In-One Printer
HP Photosmart Premium c309a series will not print
Prints blank page
    Scholar:
  • 156 Answers
Check the ink cartridges? dry ink can't print
Posted on Dec 01, 2012
PeteG0429
  • 34 Answers
SOURCE: prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Posted on Apr 01, 2009
PeteG0429
  • 34 Answers
SOURCE: Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Posted on Apr 02, 2009
bob_computer
  • 3153 Answers
SOURCE: HP C7250 w Vista PC inserts a blank page between every printed pg
You have told it to print a "seperator page"
your hp software has this setting and you need to turn it off
Posted on Aug 23, 2009
sgoswami
  • 114 Answers
SOURCE: HP Photosmart Premium c309a series will not print
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Posted on Sep 21, 2009
Testimonial: "Still not working. Great idea, tho."
SOURCE: Photosmart c309a fax confirmation?
To enable fax confirmation via the device control panel
1. Press Setup.
2. Select Print Report, and then Fax Confirmation.
3. Select one of the following: On Fax Send, On Fax Receive, Send &
Receive
4. then press OK
Posted on Dec 11, 2009
HP Photosmart Premium c309a series smudging wedding invitation envelopes badly. I can print the invitations and everything else just fine. Any suggestions? Thank you.
when you go to print your envelope and click the print command - a window will open with the name of your printer and a box that says properties. click on properties. Change the type of envelope stock to match what you are printing on in the next window. If you are using photo paper envelope with a glossy finish, make sure that is the print media you have set for your printer. If not, the ink will just keep smudging. it's very important to match the print stock (matte, glossy, premium ect).
Oct 09, 2011 | HP Photosmart Premium C309A All-In-One...
I have a hp photosmart premium wireless printer C309a series. it will print in black ink on normal white paper but when i use my letterhead paper, it wont print black ink at all
check your printer settings for paper quality, maybe your headed paper is of better quality and therefore thicker? and may be confusing the printer in some way.
May 03, 2011 | HP Photosmart Premium C309A All-In-One...
I have a HP Photosmart Premium C309A All-in-one printer. I am trying to print a greeting card. I bought the HP glossy greeting card. The outside prints fine (the glossy side) but when I print on the...
This could be due to the print-head clogging up, or your ink cartridges being low.
First, I would suggest cleaning the printhead.
Setup menu -> Tools -> Clean Cartridges
Then try it once again. If this doesn't work, try cleaning the print head manually, as per this guide.
http://www.ifixit.com/Guide/Repair/HP-Photosmart-Premium-Maintenance/3515/1
If the problem persists, buy new cartridges.
Dec 07, 2010 | HP Photosmart Premium C309A All-In-One...
Hi, how do I print wirelessly from my netbook to my HP Photosmart c309a printer?
when you go to print click on find printer and search it name . {the printer has to be on while doing this}
Dec 13, 2009 | HP Photosmart Premium C309A All-In-One...
1. Press Setup.
Receive
4. then press OK
Dec 11, 2009 | HP Photosmart Premium C309A All-In-One...
HP Photosmart Premium c309a series will not print envelopes. I keep getting an error message that says paper mismatch. It doesn't matter what size envelope I put in, it always gives me an error message....
Try This :
Click on "OPTION"
Regards Soumajit
Sep 21, 2009 | HP Photosmart Premium C309A All-In-One...
HP Photosmart Premium C309A  All-In-One Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
