Broken hinge on canon PC720
After chaning to a new cartridge, when I closed the top of the copier it evidently broke hinge toward the back, making it impossible to close. Are there replacement parts?
SOURCE: Replacing Canon PC720 Toner cartridge change
Not sure if you found this out yet.
The cartridge just slides out. When you lift the latch you will see the cartridge has lifted too. All you need to do is pull the cartridge toward you. It slides right out.
Posted on Feb 25, 2008
SOURCE: Canon Pc720 Copier Paper Jam
The problem with the paper jam (but not feeding) is that a small
piece of plastic that holds one end of a spring the causes the feed
gears to push against the powered gear on the back side of the toner
cartridge breaks off. So the unit does not feed (no pickup rollers
etc) and it thinks there is a paper jam (no moving paper). Orienting
the front as the side you work at, the back being the back, the
feed being the side the paper goes into and the output being the
side the finished copy comes out, open the unit. Looking into it
from the output side almost to the input on the bottom notice the
small hairlike things sticking up. Move to the left (back of the
machine) and see a few white gears all hooked into this gray metal
housing that moves up and down about 1/2 inch (It pivots). At the
top input side of this metal you will see a part of the metal that
stick up and has a small slot in it. the spring used to hook onto
this and the other end hooked to a small piece of plastic down and
more to the input side a bit, onto the upper input side of the white
plastic part that houses a shaft to a roller (fat little spring
about 1 inch long). the plastic part breaks off and you usually
can't see that a part was even there. The spring will still be in
the area. If you are handy, you can figure out how to fix it. I got
a longer spring (same strength) bent the metal toward the back 1/4"
and ran the new spring from there to a 1/16 hole I drilled in the
plastic side next to the circuit board (down low and back). I shaped
the end of the spring (where I drilled)to keep it more inside and
not hit anything. Works fine.
Steven
Posted on Mar 30, 2008
Cogz
  • 1326 Answers
SOURCE: canon copier PC720
A E2 code deals with the scanner. The optics of the copier. Has itbeen moved resently? Your lens may be off it's track. Turn the copier off and remove the copy board glass and the Black Box and try to move the lens and the scanning mirrors to see if they can move smoothly. If not you have found your cause of the noise and what needs to be repaired. It may not be worth getting fixed. That is older model, it's up to you..
Posted on Jul 27, 2008
SOURCE: gear grinding noise when copier operating
wouldn't be surprised if it turns out to be a toner cartridge. Have you had to replace it sine the noise began? Is it remanufactured / compatible? I won't be surprised if the grinding stops once it's replaced. Just my 2 cents.
Posted on Jun 14, 2009
SOURCE: Canon PC950 Copier
Hi -- The springs at the 'feeder" door broke. Now the copier wont feed, are there replacement parts? A new door perhaps? I have the same problem.. Need help or place to purchase parts.
Posted on Mar 13, 2010
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Lexmark 7600 printer cover is not seating properly after installing printer cartridge
The two hinges are attached to the back of the printer by two screws. I removed the two screws and lifted the top off, freeing the two hinges (the one on the right was broken so part of it stayed in the printer). There is a restraining line on the right side that keeps the top from coming completely free of the printer, but it can be worked around while still attached. I removed the broken pieces and the internal spring from the right side hing. The spring is what was keeping the top from seating correctly. I assume you could order a new hing, but I reassembled the printer without the spring and the top seated properly. The printer works, but I will now need to be very careful when replacing the ink cartridges because of the missing hing on the right side.
May 10, 2011 | Lexmark International Lexmark 7600 Series
I need a technical manual for a Canon Copier PC720
Scroll Down put in the 4 digit code, click download
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC720-User-Guide-TkRBNU9UYz.html
Oct 20, 2009 | Canon PC150 Personal Copier (PC 150,...
Printer top stuck in open position
Don't know if I can, BUT here's try ... jiggle the cover and see if you can slip things back. It's possible you got it too far out of alignment and it won't go back. Try something of that nature. Maybe you were too enthusiastic when you opened it. Also check to make sure there's nothing in the way, or something wrong someplace else. What does your computer say? Any message.
I have a Canon, but it's fairly new and if yours has a hinge on it that slips back, make sure your cover is high enough with your left hand so that the hinge inside the printer swings freely and slip your right hand back against the hinge and gently push. Try that. I have a PixmaM320 or something similar to that number.
I'm trying to get an old HPDeskjet1120c to print. So far, no suggestions on line or manufacturer's suggestions have worked. Steady print light, reset light off, and cartridge (bottom light) light blinks. Oh well Hope the above suggestions work for you.
Apr 25, 2009 | Canon Office Equipment & Supplies
Error message tells me the top is open it isn't,
when the top is opened there is a sensor which comes up and the cartridges come in the center.when the top is closed the sensor gets pressed due to the closed topo and the cartridges move towards in.as the cartridges are coming in between and you say top is closed this indicates that the top lift door sensor is out of position or it is not getting pressed just check out properly the sensor is getting blocked or its broken.
Mar 06, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
Jan 13, 2008 | Office Equipment & Supplies
Steven
Oct 19, 2007 | Office Equipment & Supplies
64 people viewed this question
jasbo
jasbo
