Question about Huawei Impulse 4G
Phone goes to airplane mode and will not come out.
When left for a few hours enters airplane mode. will not leave that setting without powering down, which also does not always take it out of airplane mode.
I have a kindle I cannot get o wifi I am spending hours tring to connect!
Make sure it is not in airplane mode
  1. Swipe down from the top of the screen to show Quick Settings, and then tap Wireless.
  2. Verify that Airplane Mode is Off.
  3. Next to Wi-Fi, tap On.
  4. Tap a network to connect to it.
Be sure to enter network password
May 18, 2017 | Tablets & eReaders
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
How do i take my phone off of airplane mode
That depends on the kind of phone. iPhone, you can swipe up from the home button and then tap the airplane icon.
On android, swipe down from the top, tap the little squares on the top right and then tap the airplane icon.
Dec 13, 2014 | Cell Phones
The phone alway restart when it is on.the service do not show.
First perform a hard reset by pressing and holding your lock screen/power button until your device powers off. If this does not solve your problem, set your phone into 'airplane mode' for ten seconds, and then turn the airplane mode back off.
If your device is powering off without you pressing and holding the lock screen/power button, unfortunately your device is power rebooting which can be a software malfunction or a dead cell in your battery.
Thanks,
Dish Guy
Apr 06, 2014 | Nokia XpressRadio 5030 Cell Phone
I have droid phone. Says on airplane mode. How do I turn airplane mode off?
1. Press and Hold the Power button for 2 Seconds. A menu pops up. On that list, you will see "Airplane Mode" (under which should state "Airplane mode is ON").
2. Now tap "Airplane Mode" to switch it Off. If you press the power button again after a few seconds, it should now say "Airplane Mode is OFF". This is how you want to leave it. Done.
Sep 14, 2011 | Apple iPod touch
My phone is on airplane mode. How do I get it back on?
press the power key till an options prompt pops up and gives you power options or long press your home screen and add a widget for power control or airplane mode you can also press settings wireless and network settings and uncheck airplane mode. goodluck
Mar 11, 2011 | T-Mobile My Touch Cell Phone
What is airplane mode and how do i get out of it??
Airplane Mode (Motorola CLIQ™ with MOTOBLUR™)
NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active.
To turn Airplane mode on or off, refer to the following:
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps:
1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps:
1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
Dec 04, 2010 | Motorola Mobility CLIQ Cell Phone
I cant get my phone; samsung intensity to go off of silent mode
Do you mean the Airplane Mode? You can switch Airplane Mode off by pressing the center black button on the phone (for the Menu) then going to Settings & Tools and choosing Phone Settings. The first entry on the Phone Settings menu is Airplane Mode -- select it and choose Off, then hit the center button.
Then you can go into Sounds Settings on the Settings & Tools menu if you want to choose your ringtones and whether or not your phone vibrates. You can set the ringer volume by using the up and down volume buttons on the left side of the phone.
Hope that helps!
Apr 15, 2010 | Samsung SCH-U450 Cell Phone
Txt n on the iphone
it's a workaround, but it works if you're going to leave your phone unattended...
First, go to Settings > General > Passcode Lock Turn the passcode on and create a password to protect your phone--set this to the time you prefer for your phone to go into locked mode.
Next, under the same Passcode Lock screen, set the "Show SMS Preview" to off.
Lastly, when you're going to be away from your phone, set the phone to Airplane Mode under general settings.  By setting to airplane mode, you won't get any new information pushed to you.
If you're not in airplane mode, it will still show on your home screen that you received a text message from a specific number but it won't preview the message. In order to retrieve the message you will have to go into the sms function, which will require that you enter your passcode.
It's not perfect and it requires you to think about it, but it will work for you.
Oct 17, 2008 | Apple iPhone Smartphone
Iphone does not ring on sleep mode
1. File manager in ipcsuite
/System/Library/SystemConfiguration/PowerManagement.bundle
2. Find the file:
com.apple.SystemPowerProfileDefaults.plist
Then rename it to:
com.apple.SystemPowerProfileDefaults.plist2
3. Reboot your phone
Apr 07, 2008 | Apple iPhone Smartphone
Huawei Impulse 4G Logo
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Danny Kuhlmann
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
