Hoover washer dryer cutting out
I have a Hoover HSWD 166. all the programmes run on it but no matter which programme i choose, it cuts out after about 30 seconds with the "slow spin" light flashing and the little triangle light on the time countdown is flashing too (they do 11 flashes then stop)! If i turn it off & back on to the same programme then it carries on from where it cut out but again, cuts out and the lights flash after about 30 seconds! I have checked the filter and taken the back panel off the machine but can't see anything wrong in there. i would be so greatful for any help or ideas you can give me! Thankyou.
  • 99 Answers
SOURCE: Hoover VisionHD won't drain
This is joyce
I think you better check to see first of all if it is your pump,, that is the first thing to go.
thanks
joyce
Posted on Feb 07, 2009
barkencoa
  • 3463 Answers
SOURCE: Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Posted on Jan 16, 2010
SOURCE: Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Posted on Aug 10, 2010
  • 6277 Answers
SOURCE: Hoover VHD842- About 10 mins
I'm interested in how you manage to drain the water away- is it by the filter cover? If not may I suggest carrying out the following- if you have not done so already ;-0)
(If you have -sorry. This will not help)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 26, 2011
  • 2509 Answers
SOURCE: My Hoover Nextra 6 has
It could be anything but one of the most likely things is a faulty door switch. What were the circumstances leading up to the fail ? Have you checked the filter? Is there any water in the machine?
Try unplugging it and leave it off for 15 mins.
difficult without any more clues...
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Feb 27, 2011
We are looking for a Programme Selector for a Hoover Nextra HNWL 3136
hi there my best advice is phone gias in rochdale go to gias website for number when you ring tell them you repair washing machine so you get a trade price
Jun 23, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Need to know what the programme numbers mean please!
Here is the Hoover site where you can download an instruction manual. http://service.hoover.co.uk/manuals/?Section=2 I had no idea Hoover made washers, dryers, or combo units. They only sell vacuums on this side of the pond.
Apr 21, 2009 | Washing Machines
Programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Feb 26, 2009 | Hoover Nextra HNF 3157 Front Load Washer
How to cancel pragram after wash has started
hold the start button in until disply shows programme cancelled - it'll come after programme paused just don't let go or it'll only pause
Dec 20, 2008 | Hoover AAA160 Front Load Washer
Programmes
Dear Flying fish,
happy to help,
Here is a location for this hard to find washer manual!
http://www.4domex.co.uk/cgi-bin/product.pl?PID=1081943
Please leave a solved rating before you leave the site,
Sep 28, 2008 | Hoover H120M Front Load Washer / Dryer
How to use hoover ac121
normally the numbers are the same for all uk machines, if the previous washer you used had numbers on it, just remember them and use them as you would, so if a number 2 was a 90 degree boil wash them it would be the same number for all uk machines, that is my experience, or older machines had letters example letter D = non fast coloureds
Aug 30, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
Top Washing Machines Experts
