Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
Fix impeller on try bolt leaf blower
I had a lot of shaking on the engine, then i saw that the impeller is really loose and rattles. i took off the casing and the impeller is detached and back end chewed up
  • 1 more comment
  • Jeff Bennett Dec 01, 2012
    well....i think i need a new impeller since it is completely detached....right
  • Randy Prevost
    Randy Prevost Dec 01, 2012
    or re-attach it.
    I have attached a picture of the back of the impeller....it fell into my hand when i removed cae
    Guru:
  • 887 Answers
...and then what?
Posted on Dec 01, 2012
Ryobi bp42 leaf blower making a rattle noise
first thing to check is a branch/trig stuck in the tube and hitting on the blower impeller fins
Nov 22, 2016 | Ryobi Garden
I'm not asking about a leaf blower It's a toro snowthrower model # 38600. what's the proper way to remove and replace the impeller blades?
You have to disassemble the entire front of the snow blower. This means removing the snow shroud, auger bits and then getting to the impeller blades. I did it once and it took me about 1 1/2 hrs to complete.
Dec 14, 2014 | Toro Garden
How do I remove/replace the assy-impeller assembly
dis-assemble the blower housing and you will see the required bolt to remove the assy
Dec 12, 2013 | Poulan Garden
Trying to fix the impeller
Take the unit to a mechanic with an air wrench or buy an electric impact wrench.
Gary @ Fix Ya
Dec 08, 2012 | Garden
Hi, my mccullough 32cc leaf blower stopped running??? loose parts in fuel tank???
The cylindrical part on the end of the hose is the fuel filter, the other part sounds like the the insert from the end of the return hose to the tank, if the filter has come away from the pipe dirt will now have entered the carc and will now need cleaning, the insert is to stop the return hose from coming out of the tank, you would have to remove the return hose to re fit this but it is not realy overley importent, if the fuel filter is still connected to the hose, pull it off and replace wiyh a new filter and try again.
Aug 27, 2012 | Garden
Cannot loosen or tighten a loose impeller blade bolt on a ryobi leaf blower, rgbv3100
After taking the housing apart grab the opposite end of the impeller shaft with a good set of channel locks (my old standbys weren't sharp enough). Then while holding it tightly hit the old impeller blade with some sharp raps with a hammer, knocking the blade loose (hit the blade at a tangent, it loosens to the left like a regular nut and bolt). Once the impeller is loosened it can be unscrewed by hand and replaced.
Nov 09, 2010 | Garden
The blower is incredibly noisy and starts shaking when I turn it on. It just started doing this while I was using it, it was fine before that one moment.
I would check and make sure there isnt debris in the impeller and that the impeller is tight. Also there may be 4 motor mount screws behind the impeller that have worked loose and are rubbing on the impeller- if so tighten with lock tite.
Nov 29, 2009 | Toro "Toro" Super Blower/Vac
My leaf blower only runs on idle only when choke is close. i clean the carb. 2 times and i replace the muffler
I have found that most of the homelite hand blowers have a tendancy to loosten the cylinder bolts, that causes a low vaccuum situation thru the carb and needing more fuel to run. I would recommend you completely dissassemble the engine and replace the cylinder gasket, Use the blue loc tight on all the bolts. Any of these engines that dont have a thru crankshaft to dispurse the vibration, tend to vibrate all the bolts loose.
Nov 01, 2009 | Homelite 'Yard Broom' Leaf Blower
Return spring poulan fl1500e leaf blower failed took it apart and reset it there are two short screws in the bunch need to know where they are placed there doesn't seem to be any thing obvious that is...
THAY GO ON THE LOWER BOTTEM ON THE SIDE FYI IF YOU PUT LITTLE WASHERS BETWEN THE MOTTER AND THE CASE WERE THE 4 BOLTS THAT HOLD THE MOTER TO THE CASE THAT WILL FIX YA UP
Sep 30, 2009 | Poulan Featherlite Gas Blower, with Low...
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
197 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
