Question about Troy-Bilt 25cc 4-Cycle Heavy Duty Gas Blower TB4HB EC
Need a spark plug for a troy bilt blower tb4hbec
  • 77 Answers
SOURCE: I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Posted on Aug 11, 2009
  • 74 Answers
SOURCE: leaf blower won't start. I think it's the module
If you haven't done it already, install a new plug. It's possible you're being fooled by a faulty/fouled plug. A fouled plug may not spark visibly - like if there is dirt down in the recesses of plug around the electrode. It would be a good idea to check it with a new plug before spending $80 bucks for a new ignition module.
Posted on Aug 13, 2009
  • 110 Answers
SOURCE: must run choke on all the time with troy bilt gas
First I would check your fuel filter in the tank. They use a sintered type that clogs easily then allows dirt to get into the internal screen in the Zama carb, if the filter is clean and whole I suggest to take the carb out and clean it. Remenber to only use starting fluid to clean the internal parts, as carb cleaner will melt the internal check valves and ruine the carb. Dont be afraid to take the carb apart, its not brain surgery, just start with a nice clean shop cloth and lay it out as you take it apart. The screen I am referring to is on the metering diaphragm side, thats the side with one screw on it
Posted on Nov 01, 2009
rycgl
  • 1545 Answers
SOURCE: What spark do I use
Your 31cc engine uses a Champion RDJ7Y. The gap is .020".
Posted on Jan 08, 2011
rycgl
  • 1545 Answers
SOURCE: PULL ROPE IS STUCK ON
Partial disassembly of the machine will be required to access/diagnose the exact problem. The starter/recoil unit goes on top of the flywheel and the flywheel is on the engine shaft. The obstacles will be removing the main cover (and getting it back on correctly). If you have never done this, them maybe take pictures as you disassemble it to help you reassemble. Once you reach the starter/recoil unit, you will see how it works and be able to resolve the problem. Some of these units have inferior design and engineering flaws where they mate nylon parts with metal and of course, the nylon doesn't hold up. Post back for more help if needed once you get to the starter unit.
Posted on Feb 11, 2011
Where is spark plug located on Squall 2100, 4 cycle,208cc ohv?
You will have to drop the back panel. See picture also add a link to your manual.
Troy Bilt Snow Thrower 31AS2T5F711
Feb 15, 2016 | Troy-Bilt Squall 2100 208 cc 21-in...
How do I change spark plug in troy bilt 4cycle leaf blower
Remove the plug wire boot from the plug and the use a 16 mm. socket to remove the plug. Check the gap on the new plug and install in reverse order.
Oct 14, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I got a no start on a troy bilt 31cc leaf blower. I've replaced the carb, fuel lines, fuel filter and cleaned spark arrester. The spark plug is always dry as a bone so i know its not drawing fuel. Im at a...
See if you have spark to the plug, if not replace coil. You did everything else it should start, make sure start switch is to the on position. You replaced carb are the lines connected to the correct places and not kinked. Is your clunk clean. not much else to go wrong. Good Luck......
Sep 12, 2013 | Troy-Bilt Blower/Vac 31cc, 200 MPH, 405...
Won't Start. Need manual (lost it). Where is the spark plug located so I can change it
You can get your manual here. You will need Adobe Reader installed on your computer to do so.
You will also need the serial number off of your machine to get the download from MTD/Troy Bilt.
You should find the spark plug at the end of a thick black wire. You may have to remove a cover to see it clearly.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Dec 06, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Leaf blower won't start. I think it's the module
Aug 10, 2009 | Troy-Bilt Garden
NO SPARK TO SPARK PLUG
Check the safety switch where the vacuum tube connects to the unit or disconnect Ignition switch to find failure. (Never operate unit with safety switches disconnected!)
Apr 07, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Troy-Bilt 25cc 4-Cycle Heavy Duty Gas Blower TB4HB EC Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
