Question about Samsung HP-R4252 42 in. Plasma HDTV
HDMI doesn't show up as a source any longer
When my xbox360 turns on HDMI doesnt show up as a source
  • 85 Answers
Check hdmi cable itself
Posted on Dec 01, 2012
I have random restarts on my Vizio E421VA HDTV. Are there any firmware updates?
I have the same problem but only when using HDMI connection.
Jun 23, 2012 | Vizio 42 in. LCD TV
After plugging the hdmi cable, we have the sound but no video
Some ideas:
  • Make sure the correct input is selected for your display device.
  • You may need to change the video out setting on your video source device (Blu Ray player, cable box, etc) to turn on the HDMI output port. See the video source's manual.
  • Devices connected to HDMI are sometimes picky about the order they turn on. Try turning off the video source and video device, then turn on the video source, wait a few seconds, then turn on the display. If that doesn't work, try reversing the order that they are turned on. If this is the problem, you can buy a universal remote, like the Harmony, that will start devices in a specified order.
Feb 12, 2012 | Panasonic DMPBD655 Player
I just hooked up my Xbox with and HDMI cable, however my samsung tv does not read it, and I cannot select the HDMI function in source
Ok, I don't have an XBox360 so I can't get specific but if you can't select hdmi input on the TV then you are probably not getting a HDMI signal. I would check your XBox360 set up to be sure that it is set to output video on HDMI not composit, s-video, or component. You might have to return to the last working setup and monitor so that you can see the menu to make the change.
Hope that helps,
Gil
Sep 21, 2011 | Samsung LN40D550 LCD TV
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
My xbox360 (the new one which comes with kinnect), no longer works. I turned it on this morning (4/16/11) and the green light turned red and all these different languages showed up on the screen. A E68...
E68: Voltage Error... This error means that the Xbox 360 has insufficent power to function properly. This can be caused by an error in the hard drive or the fans that make them **** up too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If that doesn't solve it, then you need to call Microsoft. They will repair it for you if it is still under warranty.
Apr 16, 2011 | Microsoft Xbox 360 Console
Power is on.but no longer shows up on tv screen, and the controlers no longer register on the xbox360
Make sure that your hdmi cable is firmly pushed into the console and the tv.
Thumbs up if this helps.
Sep 29, 2010 | Microsoft Xbox 360 Console
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
Samsung HP-R4252 42 in. Plasma HDTV Logo
27 people viewed this question
Henry  Thomas
Henry Thomas
