Question about Dewalt DW788 Heavy Duty 20" Variable Speed Scroll Saw: DW7881 Worklight
Knocking noise Dewalt DW788 scroll saw
When tighten the blade or increasing the speed getting knocking noise in the upper rocker
4 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: Saw has no power.
Does the motor continue to run, but the arm stops? It sounds like the set screw on the motor shaft is loose. See the exploded view at this link. It's called out as # 97 http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=5682&typeId=3475&documentId=333
Posted on Jan 27, 2010
sonicboomele
  • 1557 Answers
SOURCE: I lost my manual to my Dewalt DW788 Scroll saw.
he-manuals.com/dewalt-dw788-manual/ -
this should get you back on track
good luck
Posted on May 15, 2010
  • 13 Answers
SOURCE: bad knocking in scroll saw it is a dewalt dw788 20
have you double checked to make sure your tention hold down is not hitting against the upper arm of your saw?
Posted on Jan 03, 2011
After inserting bottom of blade it pulls to right when tightened
You may think that the deck on your machine is level, but it may be off. Check with a level and make sure. I believe this is your problem. GOO LUCK FRIEND.
May 27, 2015 | Dewalt DW788 Heavy-Duty 20 inch...
On my Dewalt DW788 Scroll saw, as I increase the cutting speed there is a knotting sound that increases isis very loud. How do I stop the knotting sound?
The knocking (knotting) sound could be caused by using a blade that is a bit to short or long. Often if the pinless blade has been broken just a bit then the blade is shorter then it should and it will knock. Also check that they guards are attached properly.
Dec 29, 2014 | Dewalt & Variable Scroll Saw
My Dewalt DW788 scroll saw continuously ends up speeding up and then slowing down, like the circuit board controller is blown...........the service center says they fixed it and replaced the board and...
Part is $84.00 Are the operators crowding the tool, blades sharp? Scroll saws do not cut quickly.
https://www.ereplacementparts.com/dewalt-dw788-type-scroll-saw-parts-c-1009_2631_2632.html
May 17, 2017 | Dewalt DW788 Heavy Duty 20" Variable Speed...
I lost my manual to my Dewalt DW788 Scroll saw. Could I get another one sent to me.
good luck
May 15, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Saw has no power.
Jan 13, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Dw788 scroll saw knocking/vibration sound
http://www.scrollsaws.com/SawReviews/DewltTuneUp.htm is a link to a possible solution on scrollsaws.com
It did not fix my problem. My problem is in the "CON ROD ASSY" (part #82) and I found VERY TINY almost microscopic play in the bearing. I took the assembly apart, put it back togerther SEVERAL times and on my last ditch effort, it solved the knocking noise.... I don't think it will last long and probaby just have to replace the part or try to buy the same type bearing for cheap and press it in without damaging it so I don't have to get ripped off on the high dollar Dewalt part.
Mar 16, 2009 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Dewalt DW788 scroll saw noise
hello,,,i just bought a new dw788
Jan 17, 2009 | Dewalt & Variable Scroll Saw
Dewalt DW788 Heavy Duty 20" Variable Speed Scroll Saw:  DW7881 Worklight Logo
185 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
