Question about Baby Care
I have the Vtech baby monitor model DM221-2 and the parent units aren't linking up to the baby unit. They just keep beeping and saying "Not linked". I've tried powering off, taking out batte
3 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: THE PARENT UNIT DOESNT SEEM
The units are not locking in to the same frequency and if this is new it must be referrred back . However if this was working earlier then there could be a shift in the communicating frequencies between the master and slave.
So remove battery of allthe units and replace after 15 minutes.,Try a reset if desccribed in the manual or the procedure for intial set up once again .
Posted on Sep 19, 2010
  • 1833 Answers
SOURCE: I have the Philips Avent
Will reply soon.
Posted on Apr 06, 2011
How can i reset baby monitor?
For Baby/Home/Pet Monitors, Cordless/Corded Phones, Digital Photo Frames
1-888-331-3383
Mon-Fri 7:00AM-7:00PM CST
(Baby/Home/Pet Monitor email)
Mark
Motorola Support
Sep 01, 2014 | Motorola Mobility MBP16 Digital Audio Baby...
Motorola baby monitor won't link
I would say try disconnecting the battery and waiting fifteen seconds, then reconnecting the battery.. If you can't disable the batteries...
I would recommend seeing if there is anything interfering with the wifi between the monitors.
Oct 22, 2012 | Motorola Mobility Mbp16 Digital Audio...
Tomy baby monitor srv 400 instruction
Page 1 SRV Series (Model SRV400) Q & A'sQ. My Parent and Baby (Camera) Unit have lost contact, what should I do?A. It may be possible that the encrypted code pairing both units has corrupted, to reset the code please
follow these instructions;
1. Place the Parent Unit next to the Baby Unit.
2. Activate both Parent and Baby Units by pressing their respective ON/OFF buttons for greater than
2 seconds.
3. Press the Mode/Enter Key to enter the Parent Unit's Main Menu screen.
4. Using the four-directional Navigation Keys, select the 'Add/Remove Baby Unit(s)' option and
press the Mode/ Enter Key to confirm your choice.
5. The current status shall now appear, showing all four Camera Units shaded grey;
6. To reconnect the Camera unit to the Parent Unit, using the Parent Units Navigation Keys ensure
the green circle is highlighting 'Camera 1'. Now press the Mode/Enter Key
7. Select the 'Add' icon with the plus symbol and press the Mode/Enter Key.
8. The screen will show the Parent Unit at the bottom transmitting a signal to Baby Unit
Jun 05, 2012 | Baby Care
The radio link between parent and baby unit has been lost and even after going through the registration process detailed in the user's manual link is not being establsihed. I have also removed the bat
Hi there, i have the same problem and its just over a year old now, i got a new battery but it still wont link, and keeps beeping. Did you solve this problem yet?
Nov 15, 2011 | Motorola Mobility Mbp30l Digital Video...
The 2 units are not pairing, the parent unit just continues to flash, despite running through the re-pair process
there is a very important step missing from the previous instructions.
turn both the nursery and parent units off.
turn on the parent unit.
hold menu for 5 secs until it beeps.
turn on the nursery unit.
press the 'clear' button at the very top of the nursery unit that is part of the halo where it meets the white plastic of the unit.
the parent unit waits for the signal then pairs.
every other guide i've found misses out this critical part of the process for some reason and i was just about to give up until i saw a guide on the angelcare facebook page linking to youtube showing 'extra features' of the angelcare monitor.
Sep 05, 2011 | Angelcare Ac401 Single Baby Movement Sound...
Hello, My Graco monitor shows a red light instead of the normal green light and it says "discard jetez". It also beeps. What could be wrong?
I just fixed my unit that had this same problem. You have to re-pair the two units... Turn the parent unit off. Hold the "volume down" button while you turn the parent unit back on. The unit should beep and flash all volume lights. Release the volume button and the press again for ~2 seconds. The volume lights will light up and stay on. Next, turn the nursery unit off and then back on. This should re-pair the two. I hope it fixes your problem!
Mar 12, 2011 | Graco Imonitor Vibe 2791vib Digital Baby...
Both units are switched on but the parents' unit doesn't want to connect with the nursery unit. I clearly see the nursery unit's green light that flashed to detect movement and don't understand why my...
I have the same problem. I'm guessing mine is broken and will need to be replaced. However i did read a possible solution on a site with slightly different instructions to the ones in the box that describes how to pair the two devices together.
if the nursery unit just waits 20 seconds then beep beep beeps and turns off i guess yours is broken too. I think its probably the nursery unit has stopped transmitting.
they will replace or repair a unit that less than 12 months from date of purchase with a supporting receipt.
the help line is 0845 009 1789 mon-fri 11-3pm
May 20, 2010 | Angelcare Baby Movement and Sound Monitor...
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Nov 18, 2009 | Graco Imonitor Digital Baby Monitor
Graco baby monitor just keeps chirping and blinking red. Don't' have owner's manual. Is it needing to charge or what is going on?
Try this. Your hand held unit may not be communicating with the one in the room.
If the Parent Unit is unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down
both the Parent Unit and the Nursery Unit. Wait for 10 seconds and hold the volume down button on the Parent Unit while pressing the On/Off switch until you hear a beep. When the unit powers up, release the volume down switch and within 5 seconds press and hold the volume down switch again for at least 2 seconds. All of the Sound Light LEDs should illuminate and the bottom LED will be red.
I hope this helps.
Apr 10, 2009 | Baby Gear
Baby Care Logo
4,120 people viewed this question
Top Baby Care Experts
masud
masud
Tom Chichester
Are you a Baby Care Expert? Answer questions, earn points and help others
